Question about Acer Ferrari 4005WLMi Notebook
Remember my password speed touch dial up broadband connection
Each time i connect to broadband via speed touch dial up i have to enter my password. How can i get it to remember the password.I have Windows vitsa
How do you get the ezbook pc windows embedded CE6.0 to connect to internet via dial up. Have a service, pulgged it up and unable to connect.
Dial up requires a modem instead of a LAN card. It uses an RJ-11 phone plug and not the bigger RJ-45 LAN plug. You also need a dial up internet service provider, and possibly software to make the phone call. There is a Connections setup in Internet Options, under Control Panel if you don't have the software.
So, you are right on track. Just make the call and enter the user name and password to finalize connection.
Dec 07, 2012 | CTX EzBook V92C266 Notebook
Tip
HOW TO SET UP SPEED TOUCH 5X6V6 BROADBAND MODEM
Once you have an Internet Service Provider ,ISP,
you just need a modem and phone line access,
plug modem into phone socket and then into the computer,
My example modem is.........
Speed Touch 5x6v6 - Broadband Modem
Operating System is Windows 7
log on to the modem using Internet Explorer Bar
Type 192.168.254
this will open the modems log on menu
then enter user name and password
its factory default is
user ADMIN
password ADMIN or 1234
once open there are some menu options on the main page
Speed Touch,
Broadband Connection,
Toolbox,
Home Network,
to add new user and password,
go to toolbox,
user management,
add new user
add password,(write down username and password)
change default user
save and test
should have a green tick next to new default user now
selecting broadband ... shows both your,
dsl connection and internet connection status,
with a green tick next to each heading.
Home network will show you...
all devices connected to this modems network ie
the other computers and printers etc,
connected on your network.
In network ,select your computer in the menu tree,
select configure
this give you a menu to add info about your computer
ie name info, comupters ip address,
access to the local intranet or the internet
Now lets connect to the internet
select Broadband from front page
menu will open and display
DSL & Internet Connections
here we test internet functionality.on? or off?
Now we go to your computer,
go to start
my network connections
run wizard in my network places
select new connection
follow prompts to the end.
open internet explorer
if web page opens then we are done and finished,
or
open tools and internet options,
connections and then lan settings
select automatically detect
Apply then close
Test webpage again,
when ok shut down and restart,
to save the computers new settings ,
Test again with internet explorrer.
if no connections run wizard again,
Hope this Helps,Cheers Misterdj
on Apr 18, 2010 | Computers & Internet
Where is the password for the internet connection located on the cisco
Follow this instructions:1. connect via hard wired connection (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for username and admin for password5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.9. select saveand apply. then you are good to go.
Dec 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I need to change my password on speedtouch dialup connection
To Manually change the dial up password in Windows 2000 or Windows XP - Go to your Start, Programs or All Programs, Accessories, Communications, Network and Dial-Up Connections
- Select your speed-touch connection
- Enter your new password exactly as it was given to you in the password box
- Be sure the Save Password box is checked
- Click Dial to connect to speed-touch with your new password
- Your new password will be saved when you successfully connect to speed-touch
- Be sure to save your new password in a secure location
Dec 07, 2011 | Microsoft Windows XP Home Edition English...
How do i use my nokia c3 as a modem to connect to the internet
Before you want to use handphone as modem, you need to know your service provider(ex maxis).
For maxis (example), it have many chosen for browse internet through pc using handphone as modem. First through hot ticket and second through normal prepaid. Actually i'm always using the normal prepaid. For this method, you need to change your sim card to broadband. dial *100# for menu. after it approve that your sim was change to broadband, then you need to chose amount for internet.(ex rm8 for one day). after all that was approve, then you can connect your handphone to pc or laptop. You can use Bluetooth or cable to connect. For me, i'm prepared using cable as long it have great speed.
Before that, you need to install pc suite for nokia to laptop/ pc that you use. If you don't know how to use pc suite, then use manual. after connect cable/btooth, you need confirmation from pc suite to get connected also.
then from that you can use user iterface that already in pc suite.
If you don't use pc suite, then you can use broadband dial up. Username and password will gived by your provider.
Create new connection using broadband and dial up. enter username and password, then you will connect to internet, For first using, it will need time around 1-2 minutes. thanks
Jul 01, 2011 | Computers & Internet
I can't connect internent after resetting modem
you need to re-enter the username and password for the broadband connection. Log in to the router and go through the connection wizard, but you MUST have the name and password that you were given by the provider.
May 26, 2009 | Computers & Internet
Zyxel to connect automatically
Connect your modem to internet port of the router and your computer to any numbered slot.Now open 192.168.1.1 in your internet explorer,it will ask for username and password.Leave the username blank and in password type admin.You will get the linksys page.On the setup page you can see internet connection type.select PPPoE from the drop down menu.In username and password enter the username and password which you use in dialing broadband.Scroll down and click on save settings.Turn off the router and modem.Power up your modem first and then router.Now you wont need to dial broadband.You will be connected automatically.
Mar 27, 2009 | Linksys Wireless-G WRT54G Router
Compaq presario sr2020nx ethernet adapter issue
Since youre setting up a DSL connection choose Set up broadband connection > PPPoE. You will need the username and password you were given to this account (contact customer service at your ISP for this info). Enter the info and have it remember the password. Click connect. Once Vista finds the connection, it will ask you to choose a network type (Home, Work, or Public). Select the type and enjoy. If the connection fails, recheck your username and password entries.
Jan 18, 2009 | HP Compaq Presario SR2150NX PC Desktop
MTNL INTERNET PROBLEM
Hello.
Since your ISP provided you a username and password when connecting to a broadband connection, you have to setup the router's "Internet Connection Type" to PPPoE then you need to enter the username and password that you are using to connect to your broadband.
Once you do that, the router will obtain an IP address from your ISP(MTNL) then it will give connections to your computers
Aug 01, 2008 | Computers & Internet
INTERNET PROPLEMS
you need
  • you need a phone line that is active for dial up,or non active for naked adsl
  • you need a dial up modem if you want dial up, adsl modem for broadband
  • sign up with an ISP (monthly cost) and obtain user name and password
  • enter user name and password (generaly via ISP cd) into (adsl)modem or setup dial up connection in windows
  • wait for ISP to notify you the line has been activated, for adsl, not dial up.
all should be good
good luck
Terry
Mar 30, 2008 | Computers & Internet
Acer Ferrari 4005WLMi Notebook Logo
192 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
