Question about Acer Aspire 5720 Notebook
Bluetooth key on my aspire work
Bluetooth, email, internet, wireless keys (maybe hotkeys?) on my acer aspire wont work after a friend removed viruses and set restore point, how do i turn them back on?
Ive lost my hotkeys on my keyboard
Sounds like your keyboard driver has either stopped working or has been removed. Keyboards will function as normal without specific drivers but hotkeys etc. wont work. Look at the manufactures web site for keyboard drivers, usually they are pretty good at providing the downloads. without them installed correctly hotkeys will not work. Once installed run the software and check the keys assignments.
Nov 24, 2013 | Computers & Internet
Acer Aspire AS5552-3691 LX.R4402.149 cant connect to internet
Make sure the built in wireless for this laptop is turned on, via a physical switch or using the Fn key in combination with the proper function key with the wireless icon.
If still no connection, check the source you're trying to connect to. Make sure your router is working properly and see if other devices can connect to it.
If your source is operational, and you still can't connect, two things might be happening.
1. You may have a virus on the laptop called a ******, which will block your internet connection
or
2. Your wireless card may be failing.
Download some virus removal software (Malwarebytes, SAS, Combofix) and try to remove the viruses. In the end, the best thing to do is take it to a trained computer technician so you don't accidentally delete something you need off the computer.
Sep 12, 2011 | Acer Aspire One PC Notebook
My acer aspire 5735Z tells me that the wireless facility is switched off. windows suggests that there is a switch on the front or side of the pc to press but there isnt. is there a hotkey? I have used it...
There is either a dedicated switch or a function switch. Function switch works like a capital letter, but using the function key instead of shift key.
Oct 01, 2010 | Acer Computers & Internet
How to switch off my wireless device?
could be a "hotkey function they are different for each pc
you might try FN-F2
if this doesnt work consult manufacturers manual/site for further instructions to define which key/key combination it is
Sep 07, 2010 | Acer Aspire 5735 Notebook
My Acer Aspire One PC Notebook speakers stopped working
Hotkeys
The computer employs hotkeys or key combinations to access most of the
computer's controls like screen brightness, volume output and the BIOS utility.
To activate hotkeys, press and hold the <Fn> key before pressing the other key
in the hotkey combination.
<Fn> + <F8> Speaker toggle Turns the speakers on and off.
<Fn> + < > Volume up Increases the sound volume
(only for certain models).
<Fn> + < > Volume down Decreases the sound volume
Aug 26, 2010 | Acer Aspire One PC Notebook
My computer does nor recognize wireless internet
Have you checked to see if the wireless has been disabled?
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Hope this helped!! Comment if you need more clarification.
Feb 16, 2010 | Acer Aspire 5040-3810 Notebook
How do u turn on the wireless capability on an acer aspire 4810TZ?
The "Communication Key" controls the wireless function. This key is located above the keyboard on the right. There are a series of keys together to the left of the right speaker port. The communication key is the far left key in this group of buttons.
If you are trying to enable bluetooth simply press the fn+F3 key to turn bluetooth on.
Jan 09, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Have an acer aspire one and have sky broadband wireless internet but it wont connect it just keeps asking for the security key which i keep inputing i dont know what else to do
if its continually asking for a security key, maybe someone changed it on you without your permission. it can be done by anyone who has a little networking knowledge.
Oct 31, 2009 | Acer Aspire One PC Notebook
Bluetooth
Hi
Try and download and then reinstall the driver for it :
http://support.acer-euro.com/drivers/notebook/as_5100.html
Choose your operating system.
Apr 26, 2009 | Acer Aspire 5100 Notebook
Acer TravelMate 4020 Blutooth
does not have ! Look at the "communication" tab
Acer TravelMate 4020 Notebook Specification:
Operating System Linux BE (Basic Edition) Platform Intel® Pentium® M processor 725 (2MB L2 Cache, 1.6GHz, 400MHz FSB)
- Intel® 915GM Express Chipset
- Intel® PRO/Wireless 2200BG Network Connection 802.11b/g Memory 256MB DDR2 SDRAM, upgradeable to 2GB Display 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Graphics Intel® 915GM integrated 3D graphics, featuring Intel® Graphics Media Accelerator 900 and up to 128 MB of shared memory, supporting Microsoft® DirectX® 9.0 and dual independent display Audio Audio system with built-in speakers
MS Sound compatible
Built-in microphone Storage 60GB ATA/100 HDD Optical Media Drive DVD/CD-RW Combo Drive Communication Modem: 56K ITU V.92 modem
LAN: 10/100 Mbps Fast Ethernet
Wireless LAN: integrated Intel® PRO/Wireless 2200BG network connection Size & Weight 364 (W) x 279 (D) x 33.9/38.9 (H) mm (14.3 x 11 x 1.3/1.5 inches)
2.95 kg (6.48 lbs.) Power ACPI 1.0b power management standard
32.6W Li-ion battery pack (4-cell), battery life: 2.5 hours Special Keys & Controls 88-/89-key Acer FineTouch™ keyboard with 5-degree curve, inverted "T" cursor layout, international language support, 2.5 mm (minimum) key travel
Touchpad with 4-way scroll button
12 function keys, four cursor keys, two Windows® keys, hotkey controls, embedded numeric keypad
Four easy-launch buttons: Internet, email, Empowering Key, one user-programmable button
Two front-access LED-buttons: WLAN, Bluetooth® I/O Ports Three USB 2.0 ports
PC Card slot (one Type II)
External display (VGA) port
Headphones/speaker/line-out port
Microphone/line-in jack
Ethernet (RJ-45) port
Modem (RJ-11) port
DC-in jack for AC adapter Software Optional Items Li-ion battery pack
65 W AC adapter
256/512 MB or 1 GB DDR2 533 soDIMM memory modules
External USB floppy disk drive Warranty 1 (one) year International Traveller's warranty (ITW) Price
Jan 21, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 5720 Notebook Logo
126 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
