Question about Microsoft Windows XP Home Edition
Error Message when logging in to Windows XP
When logging in to Windows XP, I receive the following error message:-
SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Can you please help?
    Scholar:
  • 165 Answers
Please follow the steps at the link below to solve the issue:
http://support.microsoft.com/kb/310353
Posted on Apr 14, 2009
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Hi wht to do as error 0x000000ED
When you first restart your computer during the upgrade to Windows XP, or when you start Windows XP, you may receive the following error message:
STOP 0x000000ED (0xaaaaaaaa,0xbbbbbbbb,0xcccccccc,0xdddddddd)
UNMOUNTABLE_BOOT_VOLUME
Note In this error message, aaaaaaaa, bbbbbbbb, cccccccc, and dddddddd are hexadecimal numbers that may vary.
If you receive this error message when you restart the computer for the first time during an upgrade to Windows XP, your original operating system will still work correctly. In some cases, you may see a message that states that the wrong cable is being used. However, you may not see this message on computers that have a fast startup time.
Advanced troubleshootingThese methods are intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help, use the Microsoft Customer Support Services Web site to find other solutions, or contact Support. See the "Next steps" section for more information about the Microsoft Customer Support Services Web site.
Begin by reading the "Technical information about the error" section to understand why the error might be generated and the purpose of the message. Otherwise, you can skip this information and begin with "Method 1: Check the error message" to help you resolve the issue. Technical information about the errorThis section provides some technical background about the cause of this error message and why it might be generated.
This behavior can occur if either of the following conditions is true:
  • Your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and the following conditions are true:
    • You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
    • The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
  • The file system is damaged and cannot be mounted.
The purpose of this error message is to prevent the following two things:
  • Potential data loss caused by using an incorrect IDE cable for the faster UDMA modes. An IDE cable is a kind of cable used to connect storage devices, such as hard disks, inside a computer.
  • Continued access to a drive on which the file system is damaged
Feb 02, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
Microsoft Visual C++Runtime Library
hello there
please follow this link for a explanation and a fix for this ok
  1. "Microsoft Visual C++ Runtime Library Runtime Error" error message ... Describes the error messages that you receive after you install Office XP or an ... "Microsoft Visual C++ Runtime Library Runtime Error" error message after you ...support.microsoft.com/kb/307817
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
Lost right click capabilites.
You may experience any of the following symptoms:
  • When you right-click a file, Windows Explorer may quit unexpectedly, or you may receive an "Access Violation" error message, or you may receive the following error message: Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience. When you view the details of the error, you find an error signature similar to the following: AppName AppVer ModName ModVer Offset
    Explorer.exe 6.0.2800.1221 Ntdll.dll 5.1.2600.1217 00054084
  • After you install Windows 2000 Service Pack4 (SP4) or the 823980 security patch (MS03-026) documented in MicrosoftKnowledge Base article 823980, you may not be able to open .max or .drffiles in the following products:
    • Discreet 3DS Max versions 2.x, 3.x, 4.x or 5.x
    • Autodesk Architectural Desktop 2004
    • Autodesk Building Systems 2004
    • Autodesk VIZ 4
    • Autodesk 3D Studio VIZ R3 or R3
  • YOU CAN RESOLVE THE PROBLEM BY VISITING HERE
Mar 25, 2009 | Microsoft Windows XP Home Edition
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Microsoft updates
Most of the time when updates cannot be installed, is because you have installed a file that is newer than the one provided by Microsoft, or you already have the "update" and Microsoft gives you the error.
Essentially when your computer communicates with the Windows Update website. It uses TWO technologies called:
Active X - to interact with the Microsoft site. The first time you visit the Update website, using your profile, you are asked if you will accept the Windows Update Control Package (the Active X control) onto your machine.
SSL (Secure Socket Layer) - A method of data encryption used by Internet Explorer.
Now this general error message 0x800A138F, that some folks get when they visit Windows Update, has been around for a while. BUT, when the MSBlast virus was unleashed Microsoft changed a few things at the main update website. One of them was to use Akamai for additional bandwidth and this connectivity is exclusively using HTTPS (SSL) for the downloading of the update catalogue. It is since then that we have seen an escalation in the number of 0x800A138F error messages!
The following steps will help many of you... BUT
What would be REALLY helpful to anyone trying to support you, is if you go to the "Windows Update Log" and look for any "Errors". This gives a clearer indication as to the exact nature of the problem. (The 0x800A138F error message is a "General" error THE real error number is in the log. A list of possible error messages is in a table at the bottom of this page.)
The windows update log is in the following places:
C:\Windows\Windows Update.log (Win XP & Win98/Me)
C:\WINNT\Windows Update.log (Windows 2000)
Just copy and paste the above in Windows Explorer to open the log file...
Feb 26, 2008 | Microsoft Windows XP Professional With...
Microsoft autoroute
Hello Sir / Madam,
1.If you are using Microsoft Windows XP or an earlier version, click Start, click Run, type regedit, and then click OK.
If you are using WindowsVista, click Start clip_image001.jpg, type regedit in the Start Search box, and then click Regedit in the Programs list.2.Delete the following subkeys from the registry:
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanner.1
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResult
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResult.1
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResults10
HKEY_CLASSES_ROOT\Microsoft.MapPoint.WiFiScanResults10.1
Note Make sure that you delete every registry key because you will receive a different error message every time that you install the program.3.Install the program that you want.
Jan 04, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
