Pride Rally 3 Wheel Scooter  Logo
Posted on Sep 07, 2013
How to bypass key switch on pride legend side kick, lost key.
Harry Sappington
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Apr 18, 2014
Harry Sappington
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
4400
Points
47
While this can be done I do not suggest it. The lock out system is then overridden and the scooter can become dangerous. Also the charger and other electronics will not function correctly. Replacing the switch can be easily done. Parts can be obtained through monsterscooter.com
1 Related Answer
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Oct 01, 2009
SOURCE: Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Can't get seat off my Pride Legend
You manual merely says this on Page 26
Make sure the seat is locked in position.
Lift the seat off.
https://manualzz.com/doc/8931129/pride-legend-owner-s-manual
There are some videos for Pride Scooters here
https://www.google.com/search?q=Pride+Legend+remove+seat
I'm trying to fix a pride victory twin it flashes 5 times
NEVER EVER Bypass stuff. They are there for a reason and it is normally safety!
? ? ? ? ? (5) The manual freewheel lever is in the (forward) freewheel position. Remove the key from the key switch, then push the manual freewheel lever to the drive (rearward) position and restart your scooter
Page 37 of your manual!
https://www.pridemobility.com/pdf/owners_manuals/intl_scooter/canada/english_pdf/ca_victory_twin_om.pdf
How to reprogram my Pride legend XL Mobility Scooter?
What would you like to program it to do? It is a Mobility Scooter. Turn the key on, and twist the throttle and it moves. It is a battery, a potentiometer and a pair of electric motors.
Here is the Owner's Manual
https://www.pridemobility.com/pdf/owners_manuals/intl_scooter/canada/english_pdf/ca_legend_xl_om_e.pdf
Question tidied up and put in the correct category :>)
How to bypass pass key moduler on 91 cadillac
this can b done in kick panel driver side is relay switch to be cut out and bypassed
1helpful
The kids drove my Pride Legend XL through a puddle. I doesn't go anymore. I need a technical Reference Manual with schematics. I could fix it myself or......? Batteries are fully charged. No...
I had a similar problem with my Pride Legend XL when I drove it
through a puddle accidently and some water splashed up underneath
the motor controller. It would buck or go then stoo without any warning
as the electric brake was applied. Had to take the seat off and use a
hair dryer on the controller connections to dry them out. It doesn't
seem to take much water to make these inoperative. After thoroughly
dried out with a hair dryer..no more problems like that with it.
2helpful
Lost key to Pride Celebrity Scooter. Have an extra key for another Celebrity scooter. Are keys interchangeable? Thanks, DJ
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
1helpful
2answers
The right hand side indicator does not work on my Pride Legend Classic XL8. I have checked the fuses and they are ok. The left hand side indicator and the hazard flashers work perfectly. Please help.
Hi if when you put the hazzard lights on all the indicators work then this suggests the problem is with the indicator switch, you may need to get it replaced, it could be that it has got corroded due to rain or damp getting in, if the hazzords are working ok then you know the fuse and bulbs are good so all thats left that could be wrong is the switch that works the indicators.
this will need removing and replacing to solve your problem
2helpful
Regards
GeWiz
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
