Question about ASUS A8N-SLI Motherboard
Up date my bios and copy my bios procedure - ASUS A8N-SLI Motherboard
  • 3,267 Answers
You will be able to update your BIOS from asus web site. Just fill in the details and get your update.However a BIOS update should only be done if this message appears during any operation of the PC.............sodeep
Posted on Apr 14, 2009
WHO MAKES BIOS FOR TECRA?
ACPI Flash BIOS version 3.20 for Tecra A8 (PTA82) Posted Date: 2016-09-19 ' Version: 3.20 ' Size: 3.82M ACPI Flash BIOS version 3.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 3.30 ' Size: 3.82M ACPI Flash BIOS version 1.40 for Tecra A8 (PTA82U) Posted Date: 2016-08-24 ' Version: 1.40 ' Size: 3.54M ACPI Flash BIOS version 1.60 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.60 ' Size: 3.52M ACPI Flash BIOS version 1.50 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.50 ' Size: 3.54M ACPI Flash BIOS version 1.30 for Tecra A8 (PTA82) Posted Date: 2016-08-24 ' Version: 1.30 ' Size: 3.54M
Apr 02, 2014 | Toshiba Tecra A8-EZ8311 Notebook
Bios battery removal
the bios/cmos battery (usually a button type) is fairly easy to remove and can be done anytime the computer is unplugged from the power (switched off at the wall) however it is recommended that this procedure only be done by trained personnel
NOTE: removing this battery will reset the system date and time
Feb 12, 2014 | Intel Computers & Internet
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
Bios password dell e5510
The BIOS password may be removed by removing the BIOS battery from the notebook for 20 mins. If you cannot wait for this period, then short out the battery contacts for a few secs.
Replace the BIOS battery and go to the BIOS configuration and set the Date & Time etc.
If this procedure does not work then try this WEB site for BIOS passwords :-
http://www.biosflash.com/e/bios-passwords.htm
Oct 07, 2010 | Dell Latitude E5510 Notebook PC
My computer does not start up; it displays "COMPAQ" only.
are u able to enter the bios, if yes then there is a problem with the hdd and the memories, check the hdd cables and clean the memories. if possible plz install a clean copy of windows.once done also upgrade the bios of ur motherboard to latest
Jan 11, 2010 | Compaq Presario 5000 PC Desktop
I have problem on bios password.i disable the bios password but it asks for the password and when i entered the old one and it doesnt work. acer aspire 4715z
Below is the factory service manual.....it is free to copy, use and print. You will need adobe acrobat reader or fixit read it now to view this file. The BIOS password reset procedure is on pages 39 and 40 of the manual. It involves "shorting" two contacts on the motherboard while powering up the laptop. Read the procedure carefully and you will be fine. If you find this uncomfortable, a local shop should be able to perform the procedure for you.
http://tim.id.au/laptops/acer/aspire%204715z%204315.pdf
Nov 11, 2009 | Acer Aspire 4720 Notebook
I need to replace the battery in my computer. I have the manual. Has anyone done this? Can you follow the procedures in the manual or is there a better set of instructions to complete this job?
Here is a step by step tutorial from Dell:
http://support.dell.com/support/edocs/systems/dim4600/en/4600/sm/battery.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 07, 2009 | Computers & Internet
Windows vista has does not response when i install it , and i find the problem that the bios software is out of date so i will work to update the bios but i cant know how can i update the bios can you help...
To explain how to update the bios, would be very difficult, as it is a strict method to complete.
And would be a very lengthy conversation.
below is a link to the procedures for you
(WARNNG) you must get it right first time.
Flashing the Bios is not difficult, it must be right.
http://www.wikihow.com/Update-Your-Computer's-BIOS
Take your time, soak up the method's and procedures, practice the procedures in the steps,
Go for the BIOS update, only when you are confident that you have understood all the topics involved.
You will need a working, online Pc system,
so you can download and get the updates.
Hope this helps
Regards.
Richard.
Apr 20, 2009 | Computers & Internet
BIOS PROBLEM
I don't think you have a problem with the BIOS version but more likely with the settings.
Please enter in the BIOS and be sure that under: main menu, ide configuration, Parallel ATA IDE controller is set up as Primary. Then you go under advance menu, Serial ATA IDE controller and be sure you don't have RAID.
Copy of the manual can be find here http://dlsvr.asus.com/pub/ASUS/mb/sock754/k8v_vm_ultra/e2476_k8v-vm_ultra.pdf
Let's start with this checks and then let me know.
Sep 28, 2008 | Ultra (31624) (ULT31624)
ASUS A8N-SLI Motherboard Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
