Question about Vacuums
The 10 amp thermal fuse on my Panasonic MC-E468 vacuum cleaner has blown. Unfortunately the red ink has worn off exactly where the temperature rating is printed so even with a magnifying glass cannot make out the exact replacement fuse to buy. Can anyone shed any light. I know you can buy the complete thermal fuse and wiring from currys partmaster but with delivery would cost about 20 pounds as opposed to 69 pence for the fuse itself. Thanks Mark Roberts
  • Philip Gaut May 11, 2010
    May be able to help, but on wrong computer at the moment.  Will get back to you later if I can find what you need.
  • Dennis Nicholas Feb 04, 2012
    99 deg C
    President:
  • 389 Answers
It appears the fuse is not available separately. Standard retail price for the complete unit is £9.00 including VAT. We can supply at that price plus postage and packing at cost, which would probably be no more than £2.50.  If this is of interest to you, please reply with an email address where I can contact you direct.
Posted on Apr 16, 2009
  • Bruce Mackett Mar 02, 2012
    Hi Philip what company do you work for ad how can I get the fuse and wiring assembly mentioned. Regards Bruce Mackett
Panasonic mc e468
My guess is it has plastic teeth that latches on somewhere, use flathead screwdriver gently to see if it'll budge. Normally the bottom is where it detaches, start there.
Jul 14, 2014 | Vacuums
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Is there a fuse in panasonic model mc cg885 vacume
http://www.panasonic.com/consumer_electronics/vacuum/default.asp
go to the web and see your model and download from read the instruction manual, section troubleshooting.
Some models have thermal fuse.
God bless you
Sep 16, 2012 | Panasonic MCCG885 Bagged Vacuum
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Feb 24, 2009 | Panasonic Vacuums
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Trying to replace the mains cable on uproght cleaner mc e468,but having great trouble getting the plastic covers off
first remove handle
single screw rear of cleaner and slide handle horizontally rearwards
remove access cover (2 screws) for electrical connections and switch
Aug 09, 2008 | Panasonic Vacuums
Lights are on but motor won't run?
I had the same problem, and i found this is the user guide: problem: Tripped circuit breaker/blown fuse at household service panel. Solution: Reset circuit breaker or replace fuse so, i've replaced the fuse (my friend did) and it solved it.
Sep 14, 2005 | Panasonic MC-V5005 Bagged Upright Vacuum
Vacuums Logo
378 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
