Question about Asrock P4i65G Motherboard
Memory wont work
What pc speed can motherboard take have bought 2 x1gb sticks of pc3200 not working
    President:
  • 2,692 Answers
 Look in the manual for your model:
Link to your manual:
http://www.asrock.com/mb/manual.asp?Model=P4i65G&s=478
Posted on Apr 14, 2009
THANK YOU ALL FOR YOUR HELP, BUT THE USER GUIDE WAS THE WRONG ONE. I NEED ASUS K8V-VM PLZ. HAVING TROUBLE FINDING ONE..
That motherboard with support 2 x 184 pin 1GB memory sticks. It supports PC3200, PC 2700 or PC 2100. You can mix and match but note that both memory sticks will operate at the slowest stick's speed.
Jun 22, 2013 | ASUS K8V-VM Ultra 1GB DDR PC-2700 Desktop...
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
I have p4p800 se 2.6 ht cpu I recently bought 2-1gig sticks of ddr400 pc3200 cl3 hp memory and tried everything I could think of wont boot can anyone help
Asus gives this as the board memory spec:
-4 x 184-pin DIMM Sockets support max. 4GB DDR400/333/266 non-ECC DDR SDRAM memory
I suspect you bought DDR2 type memory.
Apr 16, 2010 | ASUS P4P800 SE (890552603657) Motherboard
I intend to install more 1 mega of memory, but motherboard not recognized it (one dimm 1gb pc3200 cl3 184-pin dimm). Of origin the PC it has been installing 2 dimms of 512 and I intend to add +1 dimm of...
The memory may not be compatible depending on the speed. Try taking out all the memory and just installing the 1Gig stick.. does it work?
If it does then the 1Gig stick is fine, but your PC probably doesn't like you mixing different types and speeds of memory.
If it doesn't work, the 1gig memory module might not be the correct speed your PC wants.
Sep 08, 2009 | Computers & Internet
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
May 02, 2009 | Asrock P4S61 Motherboard
What speed,or memory that runs best in a syntax svm266a m.b.
The pc3200 would be best.
Do not mix different speeds together.
I'd go with the max of 2gig.
Mark
Mar 28, 2009 | Syntax SVM266A (SYSVM266A) Motherboard
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
Memory for the D4362
Your system may have 2 slots for SDRAM and 2 slots for DDR Ram, and must not be mixed, either use only DDR DDR2 or SDRAM. The mobo may only take 2 of the same size sticks e.g 2 x 1GB,or 2 x 256MB, so be carefull as you may waste money on a non recognised peice of ram. If you use a pc3200 and a pc2700 stick it will run at the slower speedof pc2700. Some boards will only allow a certain maximum of ram up to pc3200 speed and then adding any more you will have to run at pc2700 speed. The crucial memory site will be best for advice on memory type allowance and speed.
Jan 29, 2007 | E-Machines D4362 (RBD4362) PC Desktop
Asrock P4i65G Motherboard Logo
119 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
