Question about Electrolux Washing Machines
Electrolux EW 1280 F won't start
Won't start, timer blinking and no error message.
Random first but no life sign at all now.
Thanks for any help.
4 Suggested Answers
SOURCE: electrolux ew 1280
Must be an Error Code, please refer to the owner manual
Thanks....!!!!
Posted on Jul 31, 2008
  • 174 Answers
SOURCE: washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Posted on Jul 20, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a kenmore het5 washing machine. I
It is indeed F20 is it flashes when no water/insufficient water is coming into the machine or when the pressure switch fail to trip after a certain period of time in which sufficinet water must flowed into the machine. The water tap hasn't been opened and hence the F20 code.
Unplugging the machine allows the controls to reset forcefully and eliminate the possibility of an electronic glitch. But it must be unplugged for at least 15 minutes in order to allow the capacitor to discharge and the controls to reset. The longer the machine is unplugged, the better. Also make sure there's power from the outlet where is plugged into including the breaker feeding the outlet.
Indicate the exact model number of the machine if further advice is needed. You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jun 28, 2011
Hi I have an Electrolux EW Aqualux 1200 in a rented property no manual for the programs would you be able to email me one if available Many thanks rachel
rachel you will find it here if its model number is ew1200
http://www.manualslib.com/download/46075/Electrolux-Ew-1200-I.html
Jun 21, 2016 | Electrolux Washing Machines
Fix e 15 error code on electrolux induction range model ew 30is6cjs have turned off barker to allow for reset. still get error code
Good Morning friend, thanks for your post!
I see your Electrolux range is displaying "E15" error code and you have reset your appliance but continue to receive the message. An "E15" error code stands for ESEC (Electronic Surface Element Control) self-test failed which could be a possible issue with your relay board or UIB (User Interface Board). I suggest seeking assistance from a technician to properly diagnose and repair your appliance to avoid any unnecessary part purchases. -Matt
Sep 26, 2014 | Electrolux Kitchen Ranges
Electrolux 8kg won't run
This is probably normal operation , you can press the start/pause and cancel button at the same time to see if you have a error , if you get E00 this means no error if you get a E21 (example) then look and see what that error is
Feb 20, 2013 | Electrolux Washing Machines
Have to slam dishwasher door to make it go electrolux 4000
Hello David Horn - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 18, 2012 | Electrolux Dishwashers
Electrolux dishwasher
Hello - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 05, 2012 | Electrolux 24 in. ESL4125 Dishwasher
My dryer won't start unless i find the right spot
Hello would you happen to have the model number of your dryer? It sounds like you actually have two issues one being the timer itself and the other being either a hi limit thermister but the timer would be the last thing that you would test. If you happen to have a multimeter when you message me back your model number I can locate your schematic showing which parts that you would test by assuring each has continuity.Here is also a video on basic ways to test and diagnose heat issues with a dryer click this link http://www.youtube.com/watch?v=f1rebeCMVsk if you have any questions message me back those as well. I await your reply Thanks
Rick
Sep 16, 2011 | Roper Dryers
I need to verify my email address with facebook before I can interact with the people on that website, however when I ask facebook to resend the verification message I get an error message. I can't...
Facebook sends an email confirmation to the email you used when you signed up. Go to that email and click on the link in the body of the message.
Then go into facebook and sign in with that email address and password.
I hope this helps.
Please rate my answer with 4-thumbs up.
Thanks.
Aug 05, 2011 | Computers & Internet
Electrolux ew 1280
Thanks....!!!!
Jul 30, 2008 | Electrolux EW1209i Front Load Washer /...
Washing Machines Logo
124 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
