My laptop wont turn on the battery light in front blinks when i push the power button
  • 143 Answers
Unfortunatly if you are sure your laptop is fully charge, this would indicate a hardware fault in your laptop.
I would bring this in for service in order to get it working again.
Keep in mind that opening the laptop up yourself may void its warrenty.
Hope this helps,
Nathan.
Posted on Apr 14, 2009
Toshiba L655s5065RD wont start , only sign of life is blinking orange light
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
Dec 10, 2012 | Toshiba Satellite L655S5065RD 156 Notebook...
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
Computer was on and was in use then the computer turned off. Won't come back on at all. It was plugged into power. When I push the power button front little lights blink on and off but nothing else...
Sounds like the battery is down so low that it won't turn on even with the power supply hooked up to it. When was the last time you changed the laptop battery? Also, check voltage of charger to make sure it can charge the battery to specs.
Jul 04, 2010 | Computers & Internet
No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 06, 2010 | Gateway MP6954 Notebook
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Can not turn on laptop.
remove battery plug in power.startup.if pc still is flashing press and hold power button until pc shuts down.restart.everthing should be ok now.wait until os is loaded then insert battery.
the battery should not begin to charge.
Dec 05, 2008 | Toshiba Satellite A45-S120 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Power
ok..remove battery..try it on ac alone..
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
