Question about Microsoft Entourage For Mac for Mac
Entourage Hot sync failure with Palm (error = #-1)
I have had no problems syncing with my Palm Pilot for two years. Suddenly when I sync, everything syncs (3rd party software) but Contacts, Memos, To Do and Calendar do not. After all the 3rd party software synchronizes, the Entourage conduit suddenly quits and enters the following error: HotSync Failure: The Entourage identity "Earl M. Swigert, Jr." could not be opened because another identity is open in another Office application. Synchronization failed. Entourage Conduit synchronization failed. ?Entourage Conduit? failed (error = #-1) Can anyone help us? Earl
  • chocoearl Sep 13, 2007
    I forgot to say that we have a G-5 Mac and are using Tungsten Palm Pilots. I did deselect and reselect "Use new devices" in the conduit settings. This worked once; I was able to synchronize. It has not helped since.
    New Friend:
Entourage Recovery is a quick and reliable utility to repair corrupt or damaged Entourage database (.RGE) files and recover its various objects including emails, tasks, contacts, calendar items, etc. This software repairs Entourage database files created in MS Entourage 2008 and 2004 very efficiently.
Raad more and free download click here http://entouragerecoverytool.blogspot.com
Entourage Recovery Tool
Posted on Jan 09, 2016
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
1. Right click Red/Blue synch icon in lower right corner
2. Select custom
3. See how many items are in two way synch
Posted on Jan 01, 2009
Suddenly when I try to sync the Treo with the MAc(OS10.6.2) I get the following message: The application "HotSync Manager" could not be launched because of a shared library error: "" I had been...
You will most likely have to reinstall Palm Desktop because either a Shared Library is always in use or it's missing. A reinstall should help.
Feb 05, 2010 | Palm Treo 755p Smartphone
Want to wirless syn with a calendar & contact list for back up. what is the best program to use????
You can use the BlackBerry Desktop Manager to synchronize your organizer data
(calendar entries, contacts, tasks, notes, and memos) between your BlackBerry smartphone and your Mac computer.
In order to synchronize with Microsoft® Entourage, Apple® Sync Services functionality must be turned on in the
Microsoft Entourage application. To accomplish this, complete the following steps:-
note:-Back up information and data before changing any settings on your Mac computer.
1) If the BlackBerry smartphone is connected to the Mac computer, use the Eject option to remove the BlackBerry
smartphone from the Mac computer.
2) Close the BlackBerry Desktop Manager.
3) Open Microsoft Entourage.
4) On the Microsoft Entourage menu bar, go to Entourage > Preferences.
5)Within General Preferences, click Sync Services.
To turn on contact list synchronization, select the Synchronize contacts with Address Book and MobileMe check box
To turn on calendar synchronization, select the Synchronize events and tasks with iCal and MobileMe check box
note:- When Sync Services has been enabled and the OK button is selected, a new dialog window appears with the following choices:
1)Replace Entourage items with Sync Services items.
2)Replace Sync Services items with Entourage items.
3)Merge Entourage items with Sync Services items.
For Additional Information:-
Before the BlackBerry smartphone data is synchronized with the Mac computer, verify that Sync Services is turned
on in the Mac OS X iSync application. This is done by completing the following steps:
1)Open Applications on the Mac computer and click iSync.
2)In the iSync menu, click Preferences.
3)If necessary, select the Enable syncing on this computer check box.
Oct 19, 2009 | RIM BlackBerry Bold 9000 Smartphone
Sync Problems
Lower right corner of PC,
1. right click on red/blue arrows
2. select custom
3. select direction of synch
4. Go into desktop
5. Click file/ Import/ Outlook
Jan 06, 2009 | Palm Tungsten E Handheld
Palm Pilot: Connection for Hot Sync
Has synch worked before on this set up?
Jan 01, 2009 | Palm Z22 Handheld
Sync Palm Pilot Contacts to Blackberry Pearl
generate a file from the palm pilot program. I think there is a application within palm pilot specifically for that purpose. Once you have generated the file move it to your blackberry manager program and sync the phone
Dec 24, 2008 | RIM BlackBerry Pearl Smartphone
HotSync error ((sys 0505) (0,841)
I also had this problem. Searched for a solution and found that the error message refers to older programs incompatible with newer models of the palm. If you do a Hot Sync on a different and/or newer model palm device there may be these incompatibilities. The usual problem programs are mypalm and mytreo. You need to delete them by
first doing a Hot Sync
going to Applications on the palm
tap on the menu icon (or the left upper corner of the display)
tap on Delete
go down the list to delete each of these programs.
Hot Sync problems should stop
If not, you need to do a hard reset and then slowly add third-party software one by one and look for problems.
Jun 23, 2008 | Palm TX Handheld
Palm M515 hot sync problem
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
New Computer, Palm M130 won't Hot Sync
Create a new Sync profile and check it again
Sep 11, 2005 | Palm m130 Handheld
Won't sync to clean Palm
It may be due to a permissions issue on the workstation running the hot sync program
Sep 11, 2005 | Palm m105 Handheld
Computers & Internet Logo
144 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
