Question about Kenmore 67082 Electric Dryer
Cf code on testing the dryer (kenmore elite oasis canyon dryer)
Hi i did the test mode on the dryer and got an cf code on the dryer to be exact i got cf flashing and after that i got (01).....any clues?
  • dmary1235 Sep 14, 2007
    the problem is also the lights dont go on as they should in test mode? can it be cf like in(control failure?)ive been having numerous problems...i did test mode because my machine was still on 22 minutes (digital display)but the clothes in my dryer were shrunk!!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 133 Answers
The "C" codes are usually just indicators used during a test mode to tell what parts of the system are engaged but are usually followed by 2 numeric digits. (eg. C:00, C:01, C:02, etc.) I've never heard of a "CF" but what it means may depend on *exactly* what the machine is suppose to be doing at the time. You could see if you can locate the appliance's 'tech sheet' that may list such codes which should be with the unit's wiring diagram either inside the machine's control console on inside the washer's cabinet in a small pocket, pouch or envelope stuck to the RH side panel. Maybe it will give you a clue as to what is transpiring? You'll need to probably take of the panel to find it. As far as i know tho- after hitting the test it should actually come up with a c:01-c:08 meaning the test is complete. As loong as it only does this after hitting test you are ok, but double check the tech list inside the panel of your dryer. Hope this helps!
Posted on Sep 14, 2007
  • 1 more comment
  • scott gregg
    scott gregg Sep 14, 2007
    I just realized i put washer in there instead of dryer, sorry. Should still be there tho-
  • scott gregg
    OK you really need to check that manual. Is sounds like a circuit failure. If your still under warranty, CALL SEARS NOW!!!!
  • scott gregg
    No where can i find a manual online so youll have to check yours that is behind the panel. But your dryer definatley needs servicing. Not something you can do yourself, im not sure specifically what the error is but its somehting in one of the boards prob. Sorry for bad news but....Warranty or service.
SOURCE:
Actually mine is the kenmore oasis elite canyon dryer [problem...help!
F20 indicates insufficient water supply. Probably a pinched or partially clogged hose somewhere, either leading to the machine or in the machine itself. Have they checked all the hoses for that?
Sep 10, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis Electric Dryer - no power (PF code)
Press and hold the "Start" button to restart the dryer cycle if the "PF" (power failure) error code appears. This code often appears when a cycle is interrupted before it completes. You may also check the breaker or household fuse, and ensure the machine has not come unplugged.
Read more: How to Repair Kenmore Elite Oasis Dryer Error Codes ' eHow.com http://www.ehow.com/how_7703883_repair-oasis-dryer-error-codes.html#ixzz1u
May 12, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
My Kenmore Elite Oasis dryer has a CF code and continuously beeps. Running or not.
The CF error is a communication failure between the main computer and the touch panel...you may have a bad or weak connection or a bad computer..I wold recommend that you contact your local Sears and ask them about recalls, and for service should this happen again.
May 07, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Error message F44 in a Kenmore Elite Dryer. What
F-44 indicates a faulty blower motor controller. $169.00 from sears
or about $115.00 from an appliance parts store. Also note: the
service technicians repair guide is usually folded and tucked inside the top of the dryer console. It contains all the F codes and disassemble and reassemble and testing instructions. Part # for the service guide is (W10035270).
Mar 31, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
KENMORE ELITE OASIS HE CANYON CAPACITY DRYER
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. This model is manufactured by Whirlpool, so maybe you can locate your model's failure codes.
http://www.repairclinic.com/0078.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 21, 2008 | Kenmore 67082 Electric Dryer
Kenmore 67082 Electric Dryer Logo
164 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
