I can't use my SATA hard disk and my DVD ROM because i wipe my computer then i install windows xp.. now i buy a substitute IDE hard disk so i can use my computer but i can't connect through the internet because the driver for ethernet adpater and modems are gone and i have no disc drivers to installed in my computer.. i hope you can help me.. also ther is no sound because all the drivers are gone,, pls help me
  • Sudeep Chatterjee
    Sudeep Chatterjee May 11, 2010
    Please mention the Make & Model of the Motherboard, if the PC is branded then its model no and what processor are using............sodeep
  • Thomas F. Schneider May 11, 2010
    Make and model of computer or motherboard?
    Problem Solver:
  • 11 Answers
Go to the manufacturer's website of your motherboard.
then look for it's model on the download section.
Posted on Apr 21, 2009
Can't install windows on FSB 800 motherboard its showing no hard disk installed in your computer but showing in the bios kindly help
If you are installing XP on a SATA hard drive then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Mar 18, 2013 | Computers & Internet
Tip
INSTALLING WINDOWS XP ON A SATA HARD DRIVE
SATA HARD DRIVE ? XP INSTALLATION
The FIX.
If enabling the SATA in the BIOS does not allow the computer to boot up with SATA hard drive then change the BIOS back to what it was previously.
on Mar 14, 2010 | Computers & Internet
Windows xp does not install
If your hard disk is a SATA disk then -
Jan 23, 2013 | AMD Phenom II X2 Processor 560 (3.3 GHz)...
I get a disk read erroroccurred after I have installed a new hard disk. How can I get my computer going again?
Aug 15, 2012 | HP Compaq nx6325 Notebook
Dfi-64 tc problems. i just to install xp (before was windows millenium )now each time when xp load appears a message saying that bus ide drivers does not installed but when i run the drivers disc...
when a person goes install windows xp they encounter the problem of not being able to find any hard disk drives installed as if they weren't connected. The hard drive is detected with no problem in the BIOS and also on start up POST, able to boot up Linux Live CDs but the hard drive is just not being detected in Windows setup. Here is the exact error message.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
Oct 04, 2017 | DFI CA64-TC Via 694T/686B Mainboard...
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
IBM NetVista M41 PC Desktop Os Install Impossible
You probably need an OEM version of XP...not that IBM version. If you buy an OEM version, you can use it many computers. A real XP disc will partition, format, and delete partitions on any functioning Hard drive. Don't buy a recovery disc, please. That just sounds WRONG.
A cheaper solution might be a new Hard Drive...but I don't trust your IBM version of XP.
Apr 07, 2009 | IBM NetVista PC Desktop
Install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Sep 28, 2008 | HP xw4600 Workstation Linux Installer...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
246 people viewed this question
David Payne
David Payne
