Question about Compaq Armada E500 Notebook
My EVO 1005V will not power up and I notice that the Processor generate a lot of heat even at start up.
What is the best processor to get for upgrade?
Here is the Fastest processor that will physically fit Turion 64 X2 TL-68, but this will use more power and generate a lot more heat. The best I would advise is the Turion 64 X2 TL-60 This draws the same power and will increase the speed to 2Ghz on 2 cores. So the extra heat produced should be minimal and your battery life should be very similar.
Aug 02, 2013 | HEWLETT-PACKARD HP Pavilion DV6325US AMD...
The power led of my compact desktop is green lighted and it is not starting the psu is ok and even the cpu fan is not working
use other processor, their might be a possible cause that your processor was been busted due to your cpu fan is not working.
Even the psu is working but if it is not enough to supply a power to your system their is also a big chance that you cannot achieve display on your system, so better to try first other psu before purchasing a parts.
hope it helps thanks.
Sep 09, 2011 | Compaq Evo D510 Minitower (Open Box)...
Battery maximum usertime&excessive heat generated while using. LENOVO G560 model Under warranty
Most newer lap top computers generate a lot of heat. The designers of the machine walk a narrow line between efficiency and customer satisfaction. The heat comes from the processor and the power supply of the screen. Designers incorporate a standard called heat pipe design into cooling the CPU along with a small fan sometimes. The heat pipe design is a static (no electricity used) means of wicking away the heat from the processor. When the temperature goes higher than the heat pipe can act, a small fan cuts in to reduce the temperature, but at a cost of using electricity from your batteries. The heat of the lap tops have caused people to seek medical help for excessive reddened legs, thus generating a medical syndrome called "Lap top Syndrome"
The batteries are LI-ion (Lithium Ion) construction and have to be re-charged with extreme care as excessive heat generated by charging can case the lithium to burn and cause a fire. Battery designers have placed a small smart chip in the battery pack to monitor the voltage levels and this chip will shut the battery down if too much heat is detected. Since the batteries are of Li-ion design, they start
Dec 29, 2010 | Lenovo G560 06793JU Notebook
Computer wont boot Evo d510
Choose within this options with regards to your monitor: 1. You could replace your monitor with a new one. 2. Or you could send someone or send it to a technician to repair your monitor.
Boot Up Problem: 1. Try checking the Power Supply Unit (PSU) if it give out 12Voltz. If not you could replace it with new PSU. 2. Check the motherboard if there are some blown out Capacitors. If there is, send it to a technician to replace it. If none, replace your Processor. That is the defective. That causes the boot up problem.
On boot up screen. Of course it will not show a boot up screen because there is a problem on your monitor. And so, there is also a problem on your motherboard (Processor or Capacitor).
Hope this might help. Thanks.
Jul 12, 2010 | Compaq Evo D510 Minitower (Open Box)...
Compaq evo desktop machine processor fan problem
your fan may have quit working if that is the case you need to replace it ASAP befor your processor over heats and fails if that happens no mre processor
Apr 02, 2010 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
My Acer Aspire 5000,keeps shuting itself down during startup
this is an indication that your computer has so many dust build up inside, CPU or the processor generates heat, even when in start up mode, when the heat doesn't dissipates somehow, there is a protection that will shut off electrical circuits to prevent further damaged to your whole computer.
that is why it is shutting by itself automatically. chances are there is a lot of obstruction in the cooling system, particularly the heat sink.
you need to send this to a technician, im afraid
hope this helps
Jan 08, 2010 | Acer Aspire 5000 Notebook
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Computer won't start up.
Hi
Its seems it the power pack in the pc.
Mar 27, 2009 | Compaq Evo D510 PC Desktop
CPU Heating Problem
Actually, when you play 3d games, it takes a lot of processor usage, thus more heat is generated from the processor. The system compensates this heat by increasing the speed of the fan. Try downloading a sensor for your processor(usually available in the drivers CD or the motherboard's website) to check if the heat is really over the limit. If it is, you may want to clean your fan, put some oil, and replace the heatsink compound. Or if you have extra cash to spare, buy a better cooling system for your processor
Sep 18, 2008 | Intel D101GGC Motherboard
Compaq Evo
hey,, Try re-seating the processor
this will ivolve removing the heat sink and fan, removing the processor then putting it back in..
You will then need to clear the cmos, to do this there is a jumper on your board named jcmos or jp1 or batt.. this is a 3 pin jumper, its currently set to 1 and 2, set it to 2 and 3 , wait 10 secnonds then set it back to 1 and 2
Verify the the power selector on the power supply is set to the correct voltage 220 or 110..
Jul 22, 2008 | Compaq EVO D510 CMT P4 2.5/20GB/256MB...
Compaq Armada E500 Notebook Logo
275 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
