Question about Canon CLC 1120 Color Copier
Canon clc 1120 error e020 04e0 how to solve - Canon CLC 1120 Color Copier
MediaMan85
  • 163 Answers
SOURCE: Canon color laser copier
E020 is a toner feed problem to the developer. First, check for broken gears or missing teeth on all the developers. That is usually the cause.
Posted on Nov 06, 2007
muleskinner2
  • 270 Answers
SOURCE: Error Message E020, 0400 for canon CLC 1120 Color copier
This error has to do with Toner concentration of the Black ( 04 ) part of the sub code. The "00" has to do with the reference level or signal value for black. Look to see if the Black toner sensor is soiled. You have to swing out the toner hopper assembly to access the sensor. You will see two thin gray cables coming down from under the control panel. Since you have access to both assemblies - toner and paper jam detect - carefully remove both and clean with canned air. Be careful since you are so near to the $800 drum. Replace both and test. If you still have problems and the drum is old, several years, and has over 40,000 copies on it, you may have to have the drum changed and I recommend a tech do it. Good Luck.
Posted on Nov 14, 2007
  • 67 Answers
SOURCE: Canon 1150 E020 04E0 Code error
change all 4 developers plus blow clean both developer sensors you can find these sensors next to the black developer assy it has one screw
Posted on Jul 24, 2008
  • 1602 Answers
SOURCE: canon clc 900 Error E020
go on line type in
canon printer error e020 and look at all the ideas to help you fix your problems
rod
Posted on Feb 03, 2009
  • 1297 Answers
SOURCE: Error codes E020/04E0 and E061/0040
Clean the thermistors and the thermofuses the first copier,to second copier vacuum cleaning the suction fan ventilator and ozone filters.
Posted on Aug 01, 2009
Error E004 - 0002 on Canon CLC 1000 (Switch Off and On again)
your triac is defective change it /or unplug it and then attach it that may help
Nov 18, 2008 | Canon CLC 1120 Color Copier
Facing Problem in Canon Colour laser copier 1120
your a, b and c side sensors are bad they are found next to each other in the transfer drum
Sep 12, 2008 | Canon CLC 1120 Color Copier
E020 02FF Error
the problem this in tolva of cian
Sep 05, 2008 | Canon CLC 1120 Color Copier
E072 error CLC 800
i need a sub code like e072-002 or 003 and so on because it can be several things generally it has to do with yopur transfer drum any where that macvhine is way outdaTED AND THERE ARE VERY FEW THAT CAN SOLVE YOUR PROBLEM
Jun 04, 2008 | Canon CLC 1120 Color Copier
Error E061 & 0070
grid bias at upeer limit
Dec 19, 2007 | Canon CLC 1120 Color Copier
Canon 1120
I don't see where you've indicated the error code. Can't really help unless you describe more of the problem or the error code and any sub code displayed on the LCD display.
Nov 07, 2007 | Canon CLC 1120 Color Copier
Canon CLC 1120 Color Copier Logo
207 people viewed this question
old marine
old marine
