Question about Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba RD-XS34 Whenever I press a button on my remote I get a DR -2 popping up on the unit's display. Can anyone help? I have also tried the firmware update & still the same. Thanks!
  • 2 more comments
  • endosmoke Dec 03, 2007
    Nope, same thing. Any other ideas?
    Thanks
    E
  • belses Dec 04, 2007
    mine is rd-85dtsb same prob want DR-1 NOT dr-2
    how do i change it back ? [no remote operation on dr-2 ]
  • josee95 Dec 31, 2007
    I changed one parameter and I receive the message DR 2. Nothing seems to work anymore. Did other people, who faced this problem, find a solution ?
  • Anonymous Mar 26, 2014
    machine displays DR-3 when buttons are pushed on the remote control
Hold down the easy-navi button and number 1 on the remote.
Posted on Nov 19, 2007
SOURCE:
Toshiba RD-85DTSB recorder remote control wont work, getting DR-Off when pressing any buttons?????
Press the HDD and DVD bottons on the player at the same time it will then show DR2 when remote is pressed. Press mode key and the number 2 key on remote, this should now work
Oct 01, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
Flashing err 16 after trying to copy from hdd to dvd.will not reset.help
Pressed display button on remote control,error went and not seen again.
Jan 14, 2010 | Toshiba RD-XS34 DVD Player/HDD Recorder
My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Mar 27, 2009 | Televison & Video
Toshiba RD 85DT DVD recorder
ok you need to press STAR Button which says mode above it and either 1,2 or 3 to find which freqency is being use. The dvd and the remote need to be on the smae on.
Oct 18, 2008 | Toshiba RD-XS52 DVD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
WON'T WORK!
In the back of your instruction manual there is a section on error codes and what to do in the event of.
Jan 29, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
HDD Corrupt
I have the XS35 and the HDD drive is curropt. Can I do the following?
1. Download the Toshiba firmware update:
http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=rd-xs34
2. Burn the ISO to a CD-R disc. ImgBurn is an excellent free burner for this.
http://www.imgburn.com/
3. Insert the CD in your unit. It will auto-install the firmware. Follow onscreen instructions. Takes about 10 minutes total.
After the update, my existing HDD shows are playable again, and I can record and playback from the HDD. I bet it would be a good idea to periodically backup your shows on DVDs, and regularly reformat the HDD.
Mike
[email protected]
Oct 18, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
Firmware update failed RD-XS34Su
If it was a toshiba supplied disk, then I should follow up with them with the failure, as it was their fix, that caused this problem, they should replace/repair this unit for you
Oct 15, 2007 | Toshiba RD-XS34 DVD Player/HDD Recorder
HIGH-SPEED DUBBING TOSHIBA RD-XS34
Press the 'Display' button on the remote control.
Dec 05, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Remote control problems
Answering my own question,Switch on recorder manually then hold down SETUP KEY and No 2 key at the same time.As this is a common fault with this recorder would advise taking note of this solution.
Oct 21, 2006 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba RD-XS34 DVD Player/HDD Recorder Logo
307 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
