Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Error message: Can not record on this disk???
I have the same problem. I get error "E335043e02. Sometimes it works and some times I get the error. Can't figure out what the problem is. Have changed DVDs, doesn't help. Do I need a new machine?
  • 1,959 Answers
Support line for this product recommends on using 8x speed DVD's for recording. Any other media apparenlty is a **** shoot as to if it will work or not. I'd try using only 8x speed DVD's. There are many,many complaints about this particular unit and given the troubles you are experiencing, if using the 8x DVD's doesn't fix your problem, I'd get another machine and rid yourself of the headaches but not b/4 doing a little research with
a site like:
http://www.consumersearch.com/dvd-recorders
or
http://reviews.cnet.com/dvd-recorders/?tag=centerColumnArea1.0
Best of luck with your problem and hope I've helped! : )
Posted on Apr 26, 2009
  • 152 Answers
Depending what kind of DVD you are putting into the player, try the opposite. In many devices, DVD-R and/or DVD-RW discs do not work. You must use DVD+R or DVD+RW discs.
OR if it still cannot read the discs.
You will have to contact Phillips regarding this. The problem is with the reading lens in the player. It is obviously dirty or damaged which will create problems in reading the DVD.
  • Philips Master
  • 19,396 Answers
E335043e02 is not the error code, but the memory or disk location where the problem occurred.
If the error message is related to a memory exception, then you can often solve the problem by doing a firmware upgrade.
If the memory is related to disk reading try a lens cleaner disk.
Solution:
Contact Philips by phone to see if they have a firmware upgrade available for this model. If a download is available you will have to burn a CD using a computer, and to run the upgrade CD on your DVD.
Posted on Apr 14, 2009
Sony DCR-DVD403 C 13:02 Error Message so won't record movies.
Place an empty disc in, format the disc, record a little scene. Turn off camcorder. Place the error disc in the camcorder, turn on the camcorder all the way to play/edit. If this doesn't work turn it to record and try to record. Worked for some of my error disc
May 10, 2012 | Sony Handycam DCR-DVD403 DVD Camcorder
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Record errors
If your dvd player only supports dvd+r discs then that is the only way it will record. It will only record once onto the dvd-rw and, since it doesn't support the re-writables, it won't be able to use this function. This is the most likely reason for the first error. The second problem is a little confusing. Is it when you are trying to record on dvd-rs or dvd-rws that it says it can't record? I hope this post was helpful (for the first error, anyway). Good luck! I hope everything works out! Sincerely, Der Strom
Apr 06, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Disk or software error
You may be copying discs that have Digital Rights Management, or DRM encoded on the disc. You should have "burn rights" before trying to run copyrighted material...accordianman
Jun 13, 2008 | KLH CDR2000 2-Disc CD Recorder
Recording Error "Can not record on this disk/E4 54037380
I had that exact same problem. I would record a bunch of dvds with no problems for months and then some and one day it doesn't work. Only this showed up E4 EA03738B. However I've found the solution. Instead of going out and returning the recorder or buying new dvds just purchase a Laser Lense Cleaner. It's a dvd cleaner. Works like a charm.
May 05, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Programming errors
Several things to check 1) Your time - set it manually and remove the automatic time set 2) Try manually recording even a few min of anything (just put on channel to record, press DVD button and DVD Record button) - does it give you an error message on that disk? If so it might be because you are using 16x and machine sometimes gets messed up and won't record on those speed disks - same with +R sometimes does this - try recording on 8x -R ones. Hopefully this helps - if not try unplugging unit from wallsocket and leave off about 30min then try setting program again etc (plus current local time) and use a new disk and see if problem still occurs - sometimes just unplugging it "resets" everything and then starts working again.
Jan 28, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Emmerson DVD/VCR EWR20V5
if yoy dont hav firm ware up date you cant fix the machine. the machine if working will on work on 4x. like i said if the machine is not working you maybe able to fix it with the firm ware up date that lets it record on 8x only, now if some of the people out ther has the firm wade update disk, they could shareit with all the people who dont, i had one but its been 2 years sence i used it, i will look for it and make it available for all
Jan 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Emerson DVd with Video Cassette Recorder EWR20V5
Try using 8x and lower DVDs and -R ones; try cleaning with CD cleaning disk and then try recording a few min again. If that doesn't help try unplugging and waiting about 30min then put in disk that was previously recorded and go to last item and play it to end (if 2hr long skip to last skip and then play until it finishes) - now try just recording a few min using the manual DVD record button and see if error comes up again - usually this unplugging somehow resets everything. Hope this helps ya'll.
Oct 25, 2006 | Emerson EWR20V4 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
