Question about Acer Computers & Internet
Restore the corrupted programs
BATTERY HAS BEEN REMOVED WHILE ACER LAPTOP IS ON, ALL THE PROGRAMS WAS CORRUPTED HOW CAN I STORE IT?
I reset my acer aspire one to factory settings and its says my selected entry is missing or corrupt and it tells me to insert a windows installation disc but i dont have one
When you restored the laptop, I assume you used the restore program by pressing (I think f10) on boot up then going through the restore program which is stored on the D partition of the HDD. If you did run it from here and it failed, then it is obvious the restore partition is corrupted. Pity it's not the Aspire as I have a restore sic or that laptop. Unfortunately not interchangeable. You can buy a restore disc for your model from: http://www.gennersales.co.uk/recovery/acerlaptops.htm Good luck
Nov 24, 2013 | Acer LX.RNT02.070 Notebook - Aspire AS5560...
My acer travelmate 8210 won't turn on
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
Disconnect accessories plugged into the computer, such as the printer or mouse, and try restarting it.
Start the computer in "Safe Mode" or use the "Recovery Console" if your laptop is able to get past the initial start-up phase when you turn it on, but does not get much further than that.
Doing this will allow you to get to your main screen, but you will have limited access to certain drivers and start-up programs.
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
work your way through the problem
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue
Run "ScanDisk" and other diagnostic tools to see if your can computer find what the problem is and repair it on its own, as the Indiana University's website recommends.
Sep 06, 2013 | Acer TravelMate 8210 Notebook
How to factory reset without recovery disk
When you need to recover part or all of the files on your Acer Veriton M460 desktop computer, Acer makes it easy to do by offering a built-in recovery program called eRecovery Management.
This option uses clean operating system files, usually stored on a separate partition of your hard drive, to correct errors or return the system to its original factory settings.
You can also use this program to write separate hard copies of the eRecovery program onto CDs or DVDs in case of hard drive failure.
Create Backup Disks
If your M460 did not come with separate recovery disks, and many machines don't in recent years, you can create your own through "Acer's eRecovery Management" program located under the "Start" menu.
Click on "Backup," select "Create Factory Default Disk" and follow the on-screen directions.
The program will inform you of the number of CDs or DVDs you need and help you through their creation.
Recovery with Disks
To use your created disks for recovery, place the first disk in the optical drive and reboot the system. As it boots, hold the "ALT" key and tap "F10" repeatedly until the computer boots and you see a screen titled "Starting Acer eRecovery."
You will see three options for recovery: to factory default, from user backup or from CD/DVD. Choose the option you desire and follow the on-screen directions to initiate the recovery sequence.
Recovery from the Hard Drive
Since Acer places the eRecovery Management program directly onto the computer, you can run the recovery option while in your desktop.
Open the "Acer eRecovery Management" program under the "Start" menu and click "Restore." You can choose to restore the computer to factory defaults and lose all the personal data stored on the hard drive or only restore the operating system and leave your data intact.
Select "Yes" on the confirmation screen and then "OK" to start the program.
Recovery Vs. Restore
When performing computer problem solving, the term "recovery" is often used interchangeably with the word "restore."
In some cases, "recovery" can mean to simply correct problems, such as replacing corrupted operating system files with good ones.
The term can also refer to "recovering" the system to its fresh-from-the-factory state, which is what "restore" means as well.
Restore Drivers or Applications
Acer's eRecovery Management program also offers the option to reinstall drivers or applications, which could become corrupted or damaged over time.
This option allows you to replace the current drivers for your Windows operating system with the ones originally installed on your system.
Under the "Restore" tab of the "Acer eRecovery Management" program, click "Reinstall Drivers or Applications" to see the content list and select the files you'd like to recover.
http://supportforacer.iyogi.com/veriton/factory-settings-6.html
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireE360/AspireE360faq40.shtml
http://support.acer.com/product/default.aspx?modelId=477
Aug 26, 2013 | Acer Veriton Z290G Desktop Computer
Reset acer
The Acer Aspire One is a netbook, not a laptop.
A netbook is a smaller, scaled-down version of a laptop. It does not have the memory capacity or graphics of a regular laptop.
It also lacks a CD drive, which means you cannot restore the Acer Aspire One with restore discs. Instead, the netbook has a built-in factory restore feature.
You can reset the Acer Aspire One to factory settings just using your keyboard.
Only restore your netbook to factory settings if you cannot fix the problem any other way.
Save any files or folders on your Acer Aspire One with flash drives.
Drag and drop files onto the icon of your flash drive.
Go to Start > Restart to reboot your netbook.
Hold down Alt and F10 when you see the Acer logo on the screen.
The recovery menu will load.
Hit Enter and then Next to see your recovery options.
Choose Factory Restore to set your netbook back to factory settings.
Follow the instructions on the screen.
Choose your time zone and language when the customization menu appears.
Reboot the netbook when you are prompted.
Restore your saved files from the flash drive.
or
When a vital file becomes corrupted, it might be necessary to restore a computer to its original factory settings.
This process also cleans up the hard drive and removes old programs that can make a computer slow and unresponsive.
But, because restoration wipes away all files you have installed or created, it should be a last-ditch effort in trying to repair a computer.
If you have reached this point with your Acer laptop or desktop, the manufacturer provides a utility to restore the factory settings.
Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop.
Click All Programs, then the Acer folder.
Select Acer eRecovery Management to open the utility.
If a Windows prompt asks for permission to run the program, click Yes.
Click the Restore button in the pane on the left side of the program window.
Click Completely Restore System to Factory Defaults.
Select the Yes option in the dialog box that asks you to confirm the action, and click Start.
Click OK in the second confirmation dialog box to restart the computer.
Click Next in the warning window that appears after the computer reboots.
This confirms that you realize restoring the computer deletes any data stored on your hard drive.
Click Next again in the Restore Destination window, and click OK in the popup that gives you one last warning about deleting your data.
The restoration process will begin.
Click OK when the utility lets you know that the restoration is complete.
The computer will restart, and Windows will finish the recovery process.
http://acer.custhelp.com/app/answers/detail/a_id/12869/kw/factory settings/related/1
May 01, 2013 | Acer Aspire V3-571G-9435 15.6-Inch Laptop
Need to system restore my acer aspire ax1700 but do not have disc whtat can i do
When a vital file becomes corrupted, it might be necessary to restore a computer to its original factory settings. This process also cleans up the hard drive and removes old programs that can make a computer slow and unresponsive. But, because restoration wipes away all files you've installed or created, it should be a last-ditch effort in trying to repair a computer. If you've reached this point with your Acer laptop or desktop, the manufacturer provides a utility to restore the factory settings.
Open the Windows Start menu by clicking on the icon in the lower left corner of your desktop. Click "All Programs," then the "Acer" folder. Select "Acer eRecovery Management" to open the utility. If a Windows prompt asks for permission to run the program, click "Yes." Click the "Restore" button in the pane on the left side of the program window. Click "Completely Restore System to Factory Defaults." Select the "Yes" option in the dialog box that asks you to confirm the action, and click "Start." Click "OK" in the second confirmation dialog box to restart the computer. Click "Next" in the warning window that appears after the computer reboots. This confirms that you realize restoring the computer deletes any data stored on your hard drive. Click "Next" again in the Restore Destination window, and click "OK" in the popup that gives you one last warning about deleting your data. The restoration process will begin. Click "OK" when the utility lets you know that the restoration is complete. The computer will restart, and Windows will finish the recovery process.
Mar 01, 2013 | Acer Aspire Computers & Internet
Aspire5551 hangs at starting windows
Shut down, unplug, remove battery, plug in ,reboot. Try a system restore/recovery, use this procedure: http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 15, 2013 | Acer Aspire 5551 Notebook
Acer arcade deluxe programe has been removed from my aspire 5740 laptop , needs re-installing.
I would suggest that the only way for this to be 'returned' to your system is to do a system restore, using the restore CD provided (or using the built-in restore function).
Unfortunately, this would wipe anything you have installed since you purchased the laptop. This would also delete all stored data/photos/pictures you have on there unless you have backed them up.
Sep 15, 2011 | Computers & Internet
Acer e Recovery Error code: 0xC0000003Open image failed. Found
The image stored on your laptop to restore it to factory original is corrupted. If the laptop still boots, try to make restore media using the acer erecovery management console, although this will likely not work if the image is corrupt. Try installing windows with these discs if you can. If not you have 2 options:
  1. Contact acer and order restore discs (free if in warranty) or about $50 out of warranty.
  2. Reinstall windows using an OEM Windows cd and the keycode on the windows sticker on the bottom of the laptop. You will have to download all hardware drivers manually though, and you will not have any of the softawre provided by acer. The restore discs from acer are by far the best option....Let me know if this helps.
Aug 08, 2009 | Acer Aspire 5720 Notebook
Crystal eye webcam
There is a utility bar that you can install that lets you change the default application folder:
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Dec 17, 2007 | Acer Aspire 5100 Notebook
Acer notebook/laptop 5920G(acer recovery management)
its dangerous to stop e rcovery process . the software may get corrupted . downlaod it again from e recovery support section of acer.com /. got oto add or remove programs and unistalll the program and try re installing it again . e recovery is a system acritical processs
Dec 14, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Computers & Internet Logo
32 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
