Question about Minolta Freedom Zoom 115 QD 35mm Point and Shoot Camera
Panoramic pictures?? is this camera capable of taking panoramic view pictures?? I just got a film developed and half the pictures were panoramic view, never happened before, don't have manual, how do I get it to happen again? can't find a button or setting on it. Please help
  • 49 Answers
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Posted on Sep 14, 2007
6ya staff
SOURCE:
My olympus e volt 500 will not display image when in shoot mode
There is a little button on the back, marked 'info'. Press it to switch from picture view to settings view. It also operates the viewfinder.
Olympus also has a good photo editing program that is free and it allows you to edit photos and stitch pictures taken pn panoramic mode into one panoramic picture. It's called Olympus Master.
Dec 12, 2012 | Olympus EVOLT E-500 Digital Camera
Can I only view a panoramic series if I print out the photos? No way to view it digitally on computer? Thanks, rj
You can view panoramic pictures on the computer. If your panoramic pictures have not been combined, their is software that can do that for you. Here is a free panorama stitching software from microsoft that you can try:
http://research.microsoft.com/en-us/um/redmond/groups/ivm/ICE/
Jul 07, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
When taking a picture the film does not advance. It must be shut off and turned back on again. After developing those pictures, the top half of the picture is black indicating that the film is not...
if the film drive cogs are all ok then its the film advance drive gears on the motor drive striped or slipping,,you could test this by opening the camera and genteelly holding the film advance cogs with your finger and pressing the shutter if the film advance cogs stop turning then the drive gears are slipping or striped? this could be caused by the after load censer in the camera not censing the end of film roll and trying to get another frame out of it? like it read a 24ex as a 36ex but the censor faled to stop the motor drive winding on and that striped the gears
Aug 09, 2010 | Canon EOS Rebel K2 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
After develop the pictures i found that some images are completely blank and the images are cut into half. Half develop and half not. what the cause of it?? thanks
Might be film coming loose when inserting in loading spool and skipping when winding forward after making a shot. Could try bending first 1/2" of film tongue before inserting in slot in windup spool so that it won't slip out and be sure film sprocket holes are engaged with film transport sprockets and a bit under tension when loading film before closing camera cover. Your 'half-frame' problem might be that you are shooting at a 'flash' shutter setting of 1/60 when not using flash.
Oct 08, 2009 | Canon EOS 5000 35mm Film Camera
Film developing clear
Hello
This problem could have a number of causes,
To check to see if it is a camera fault of developing fault you could try using a cheap colour film in the camera and getting it developed at a normal photo processor.
This will determine in which half of the process the fault lies.
If the pictures from the colour film are the same then it must be a camera usage problem or fault.
If the pictures are ok from the colour film then it will be a problem in either the film being used, developing problem (poor mix of chemicals etc).
This will just speed up the diagnosis a bit.
Oct 02, 2008 | Pentax K1000 35mm SLR Camera
PANORAMIC FILM
I have the same camera. H is for panoramic pictures. Hope this helps.
Liana
Aug 14, 2008 | Photography
Negatives were in "widescreen"
The camera has a panoramic switch on it somwhere that caused a pair of baffles to close down over the film exposing only the center 1/2 of the film. The idea is that the print from this negative would be printed as a 4x11.5 inch photo. It's basically a 8x11.5 with the top and bottom of the print chopped off.
The only other alternative is that for some cameras had a panoramic adapter to place inside the film chamber, but that would be a very difficult thing to do inadvertantly.
Cheers.
Feb 07, 2008 | Samsung SR4000 35mm SLR Camera
Weird film exposures
check the developed film if the sproket holes are intact.
check your camera without film.
(1) open the back, do it as if you were taking pictures with different apartures/shutter speeds. If you can see the light coming in from the lens (no matter how little or how fast), your shutter and aparture diaphram are good.
if not, send it for service.
(2) if yes, check that the winding sproket wheel turns when you advance film.
(3) if it goes freely, try it again with finger pressing the sproket wheel. if this stops the wheel to turn, it is the gear/shaft inside disengaged. send it for service, of course.
(4) if your camera has a button for multiple exposure, ensure that it can be turned on/off as you wish, or you do not pressed it unnoticed.
good luck
pc-cook
Jan 19, 2008 | Nikon N55 35mm SLR Camera
Pictures didn't develope
Looks like you are not loading the film onto the take-up spool correctly.
Go back to the development store and ask them if they can give you a spool of waste film (e.g. one that got exposed to the light or something). Otherwise buy the cheapest film you can find.
Load the film in the camera. Take a few frames. Open the camera back up a bit, the film should have advanced. You will be able to tell this because there is more film on the takeup spool. The frames are also numbered nearby.
It might take you a few goes to get the film to load correctly. If no luck, maybe the file wind-on is broken and the camera needs repair.
Nov 05, 2007 | Nikon N65 35mm SLR Camera
Minolta Freedom Zoom 115 QD 35mm Point and Shoot Camera Logo
119 people viewed this question
Top Minolta Cameras Experts
 Larry
Larry
ray gallant
ray gallant
Malcolm Fowler
Malcolm Fowler
Level 1 Expert
Are you a Minolta Camera Expert? Answer questions, earn points and help others
