Question about Video Game Consoles & Games
I have a ps3 that when it starts last about 3 seconds, beeps 3 times, turns itself off amd a red light flashes on and off. What is this?
  • meunna Apr 14, 2009
    Thanks. Will Try this.If It does not work. i'll give Sony a call. this is the first problem i've had with it in 2 years
  • 19,396 Answers
That is a faulty PS3 that does not complete the post because of an hardware issue, and goes in error state with the well known 3 beeps of death.
The 3 beeps are just indicating that the the playstation is doing a forced shut down with some process still running and forced to close. The error state is afterward, when the PS stays in standby because the forced shutdown was caused by a major fault.
All you can do is trying to reset the PS by leaving it unplugged for ten minutes.
If you are using HDMI cable, try connecting with a different cable (eg composite, or AV).
Try also restarting the PS with no device attached, and with paired bluetooth devices off.
If that does not work the PS# must be disassembled, tested and repaired.
Faulty parts that cause the problem are mainboard, disk, rarely wrong voltage or cut down from PSU, and any short or blown component inside the PS, or a problem with HDMI cable.
My advice is to call Sony, and complain strongly, as you have not damaged the PS or used it in the weong way.
Posted on Apr 14, 2009
I was playing a game and the ps3 just randomly shut off then the red light starts flashing and every time I turn it on it shuts off right away
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...
better u download repair guide....
click here to download repair guide
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
It turns on but nothing comes up on the tv and wont turn back off
This is a problem with your system software. Please follow these steps to fix it :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later and then beep once more and turn back off into standby(red light on) . Release the power button after it has switched itself back off.
Step 3. Again, press and hold the power button. It will beep when you first press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this an then continue to the next step.
Step 5. A menu will load with 6 options. Choose option 3 "Restore File System". Accept whatever the PS3 says and hopefully it will restart as normal.
If option 3 does not work, do the above again and choose option 4, "Rebuild Database". If this does not work as a last resort select option 5, "Restore PS3 System". THIS WILL ERASE ALL DATA ON YOUR DRIVE!!
One of these options will bring your PS3 back to life.
Hope this helps and thank you for using FixYa
Nov 28, 2010 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont stay on
charge it red light turning of and beeping is meaning its dead
Mar 02, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
I downloaded PS3 system software update 3.15 last night. Now when i turn it on the green and blue lights come on and it starts to boot up but stops and there is nothing on the screen and my controller...
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. i had the same issue and this fixed it.
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
My Ps3 isnt starting, light turns green then changes to yellow
this is the ps3 equivilent of the xbox360s red ring of death error, sorry to tell you but that means a serious system error has killed your ps3 its unfixable and you will have to send it off for a replacement
Jun 29, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont start
This seems to be a very common & recurring problem. It is the "Yellow Light Of Death". For whatever reason, the game cannot read or recognize the hard drive. There are many reasons that you can get YLOD, but it boils down to one thing... you're PS3 is kaput. Here's something you can try that may help: With the solid red light showing, hold both the power button & disc eject button simultaneously! You'll get a single beep, then a double beep. When you hear the double beep, let go. You should get a 6 point menu on your TV. Try option number 3 first. As a last resort, try number 6. This opyion will erase all your saved info, but it is a shot at rescuing your console. If 6 works for you, you can access all your downloaded games & demos at the PlayStation Store. Trophies, too. Hope this helps. If you need a walk-through, message me here & I'll see if a can be of more help to you
May 12, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
27 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
