Question about Magellan RoadMate 700 GPS Receiver
Roadmate 700 wont power up anymore
Are there any reset buttons on it that I can try ? How can it simply stop working in just 2-3 yrs ?
  • hdesh Sep 25, 2007
    so I have my unit open as you described.
    I see the power "toggle" switch.
    I suspect it might have a problem,
    because the small component in it's center
    "K" something, seems to be damaged by
    something pressing on it..
    So, where exactly did you solder the wires
    to ?
    I see a +5 and GND near the speaker
    but I doubt that that's the correct site.
    IF possible, can you name the components
    on the board, near where you soldered your
    wires ?
    thanks!!!
  • hdesh Sep 28, 2007
    Right,
    it turned out to be the connector
    actually. IT's a little deceiving,
    since the "green light" showing power
    to the connector (cigarette-lighter) is
    ON, and bright green.
    And in reality,
    the solder connecting one of the wires inside
    the connector was broken. Once I opened the
    connector, I saw the open.
    (for the others' who will run into this
    problem, the connector opens quite easily,
    it unscrews, there's a spring and fuse that come
    out and the whole assembly is easy to put back
    together)
    Soldering the wire back on fixed the problm
    and the GPS unit is "alive" with
    power now.
I had the same problem. At first intermitant and then permanent. The power connector inside the based that the head unit snaps onto had the center post fall out. You need to removed the 4 small screws located in the threaded reseases. Then using a knife I pried the plastic halves apart. You need to break the ultrasonic bonding on the plastic, but everythign seperated where it should. Now you have access to the circuit board. I soldered in 2 wires which I brought our and soldered to a cigarette outlet cord. Then I screwed it all back together.
Posted on Sep 17, 2007
SOURCE:
When i power up my roadmate 700 a message comes up that saysTemperature below safe level. mTake several minutes to warm up. but nothing happens even when its warm
Had the same problem with my MRM 700 back in 2005, only 2 months after I purchased it. They changed the connector, and it worked. BUT, few months later I had the same problem again. I haven't used it anymore since then (moved to another country), now I am trying to fix it but no warranty anymore..
Jan 28, 2010 | Magellan RoadMate 700 GPS Receiver
Power wont come on
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here.i have the mastreo 4000 and the roadmate 800 both work great.
Feb 23, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
J...
at the user menu press the "-" zoom out key the "+" zoom in key and the repeat button which is on top of your unit. Once your in the "hidden" menu, select reset user data.. your unit will reset and everything will be clean. If your trying to delete specific addresses I would use software to sync up and explore your MRM's files.
- If needed please ask more questions prior to rating -
Nov 03, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan 700 GPS wont find sattlites
I just got off the phone with India (Tech Service). I sent my Roadmate 700 for service in October. When it did not come back, I called 4x and had to prove I sent it in with a copy of the tracking number from UPS. It has taken 2 mos to resolve, but they are sending me a Maestro 4250, free shipping for $300.00. Their first offer was for a free 3100. I was told the Roadmate 700 series is discontinued.
Oct 14, 2007 | Magellan RoadMate 700 GPS Receiver
Reset
Yes, you can reset.
Access the secret " " menu and reset user data, you'd be amazed at how much that can fix. At user menu (after reset) press "-" and repeat key at the same time. select "reset user data". Also, if your having GPS problems, you can also select reset GPS data.
Post again if this doesn't work for you.
-Daniel
Sep 18, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Stopped working
Your probably right about it still not working even after the 5.32 upgrade. Although it could be the software, so try resetting GPS user data. Enter into the "secret" menu by pressing the zoom out key and the repeat button while at the beginning user menu. select reset GPS data.. If it's nothing to do with software, check your antenna and make sure none of the pins inside the connection are bent.. or the RF cable inside could be gashed/cut.. bent up.. do you hear a rattle when you shake your unit?
Apr 20, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700 freezes up
Try resetting user data. At user menu, press "-" zoom out and repeat button at same time. select reset user data, it will reboot automatically, then check to see if it is any better. If not, hopefully the software came with your unit and you can re-install it. Good luck and let me know if you need help with the installation. Daniel
Mar 03, 2007 | Magellan RoadMate 700 GPS Receiver
No map data no hard disk
Typically I'd change out the hard drive. Your not able to access your location on the map right? or are you able to access the map at all? In your position, if your product is OUT of warranty. Open your unit up and make sure the cable going from the main board (big one) to your hard drive are tight. Other then that, try resetting user data. At the user menu (after restarting) press "-" and repeat button at the same time. Scroll down to reset user data, then see if anything changes. I'm almost positive it's your hard drive, and you can't just go out and buy one of those. So, good luck.. if nothing else you can just send it down here to Fort Worth, Tx.
Dec 22, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
81 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
