Question about HP Officejet 5610 All-In-One InkJet Printer
My HP 5610 Keeps saying Cartridge Error. It never said low ink and I have changed the black ink and it still does it. Colud it be the color ink or something else.
  • Anonymous May 25, 2009
    I HAVE CHANGED BOTH CARTRIDGES WITH SAME ERRO MESSAGE.
  • Thomas F. Schneider May 11, 2010
    Is the cartridge that you put in a true HP brand? Some other brands show errors.Yes it could be another one.
  • 62 Answers
Try this link look on page #116 http://h10032.www1.hp.com/ctg/Manual/c00461378.pdf
Posted on Apr 14, 2009
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP Officejet 5610 All-In-One InkJet Printer keeps randomly popping up with cartridge error. Take the out then reinsert to no avail. changed with new. still keeps popping up
If the "new" cartridges were brand new HP oem cartridges, there are two things I would do. First, take out the cartridges and inspect the contact area (where the electrical in the printer meets the electrical on the cartridge) and make sure there is no dirt or ink on the contacts. Secondly, remove both of the cartridges, close the lid, and pull out the power cord while the printer is on. Wait at least 10 minutes, plug in, power up and wait until it is done making noises. Open the lid and insert the black cartridge first(important!) and then the color. If this doesn't take care of the issue, replace the printer. (If you're sure the carts were brand-new)
Sep 29, 2010 | HP Officejet 5610 All-In-One InkJet...
Printer says-
Remove the Cartridge.
Clean the Electrical ( golden ) contacts using lint free cloth.
Clean the Contacts inside the Cartridge slot.
Put then back in the Printer and follow the instructions on the Printer Screen.
If this does not resolve.. Contact HP Support if you are using Genuine HP Cartridge for more Help.
Jun 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridge error
replace the cartridges with new ones and clean the contacts.. its the inks... replace both of them at the same time
Mar 31, 2010 | HP Officejet 5610 All-In-One InkJet...
Hi, I replaced the black ink cartridge on my HP Officejet 5610-All-in-One successfully but the Tri-color cartridge (HP 57) clicks into place but the machine won't accept it and says Error. Please advise,...
1.check the tri color remove it from the printer then use clean cloth to clean the mess on memory chip like dust.
2. put it back into printer then try a sample page to print
3. if still don't work re-instal the software to refresh all cartridges u replace
Feb 10, 2010 | HP Officejet 5610 All-In-One InkJet...
Cartridge error: refer to device documentation to troubleshoot
remove the cartridges and clean the metal contacts with tissue paper and put it back. if the problem continues check the cartridges.
Nov 03, 2009 | HP Officejet 5610 All-In-One InkJet...
J4580 Print Cartridge Problem:[Tri-Color]Refer to Device Documen.
hi i dont have the tricolor cartridge in my hp 5610 and i want to work only with black cartridge and my printer says there is no cartridge on the left , is it posible to solve this problem and work with one cartridge only ? i can print but copy and fax doesnt work . thanx
Jul 27, 2009 | HP Officejet 5610 All-In-One InkJet...
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
362 people viewed this question
Seeker5211
Seeker5211
