Question about AcerPower 1000 (AP1000EA380M) PC Desktop
Can't install XP service pack2 on my AcerPower f6 computer.
Whenever i try to install Windows XP Pro service pack2 on my SATA disk, it hangs on starting windows. Where can I get drivers that Windows can recognise the SATA disk? My computer's model is AcerPower f6.
Urgently help please
    Problem Solver:
  • 14 Answers
Did this machine have Vista intalled originally? I checked Acers' support page for your model and I didn't see a xp sata driver.
Posted on Apr 14, 2009
I can't install windows xp on a sata disk
Some of the motherboards treat SATA as a seperate controller, hence you need to change the BIOS settings to emulate IDE settings or while installation you can press F6 while the installation starts and give the driver disk (XP accepts only Floppy disk with the driver files copied in the required format).
Please revert with the make and model number of the computer or motherboard for further clarification.
Jan 04, 2011 | Computers & Internet
When I tried to install windows xp to acerpower desktop computer it gives me a message "set up can not find any hard disk drive press F3" . Thanx for helping me.
This means that you have a SATA hard disk and you need drivers to install the hard disk first and than to continue the installation of windows.
Enter the BIOS and check for a compatibility mode for the hard drive. It should be set on AHCI. Change this for compatibility mode and try to install the O.S.
If you don't have this function, insert the motherboard CD in the optical drive and a diskette in the floppy disk drive. Boot from the CD and a menu will appear. In this menu choose the option that will create you a SATA drivers diskette. After the insert the Windows XP CD in your optical drive. But be careful because you have to install the drivers first. After the installation process is on the way take a look on the grey bar situated on the bottom of the screen. Toward the beginning of this process, a message will appear that says Press F6 if you need to install a third party SCSI or RAID driver.
You have to be quick on the trigger to press F6 to install the drivers. After this step continue the installation as normal.
If you need further assistance or you haven't understood something leave a comment.
Cheers
Jun 13, 2010 | Racer AcerPower F5 PC Desktop
Installing XP SP3 pro on my presario C700
Most likely you have a SATA drive which windows is not detecting. Restart the setup and press F6. You will need to use another system to download the SATA drivers and save to a disk. Then when prompted you can insert the disk. You can also upgrade to XP professional which will almost always recognize the SATA drives. Good Luck.
Jul 30, 2009 | Compaq Presario 700 470024-192 Notebook
I have Dell inspiron 1525 laptop with windows Vista home premium
go to bios setup n change sata driver to ATA from AHCI n  also disable da flash play module
Mar 18, 2009 | Microsoft Windows XP Professional for PC
How to install windows xp sp2 on compaq v3239tu
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
Bios not detecting bootable harddisk
Repair windows xp using bootable windows xp cd..
Mar 09, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
I have an Accer Extensa 5220 laptop which came with vista Home Edition. I wanted to down grade the OS to windows XP Pro. After formating the Hard Drive, I ran windows XP setup disk but keeps on giving the...
The problem of your laptop is the hard disk type. because acer 5220 laptop is using a SATA hardisk that automatic detected or supported by Vista. But in the windows Xp you need to download the sata driver for windows xp and save it to the floppy drive. In the beginning of windows installation press F6 to install another device or scsi the windows setup search your floppy drive for the sata driver and install it automatically. If you have cannot fix it just contact me i'm willing to help you
Apr 15, 2008 | Computers & Internet
Could not install windows xp service pack2
You need sata driver for your hdd. to install Xp you need usb floppy as well. (i.e.) for drivers for sata during xp installation.
Feb 28, 2008 | Computers & Internet
AcerPower  1000 (AP1000EA380M) PC Desktop Logo
350 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
