I have a Skyworth tv, slc-1971A-3. I can not get any channels. the dvd player works fine. I have tried the auto channel scan, but get none. What else can I do?
Skyworth SLC-1969A-3: User Manual ' Brand: Skyworth ' Category: Lcd hdtvs ' Size: 6.3 MB ' Pages: 19
can be download from the link below Download manual
The command to generate the 12VDC; from the power supply should come from the main board. S the main board should be troubleshooted in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Be sure your tv is programing with a correct signal. Air or cable channels, and that you do have a line going into the RF connector [antenna signal]. If you have a satellite or cable box your tv will only tune to channel 3. Also, if you are logged into a dvd player or vcr...you will only have one channel memory. Remove any of the external players [games,dvd,vcr etc.] And retune with auto program!
The DR-MV150B has both a digital tuner and analog tuner. Since the digital conversion you more likely have not run a channel scan for the new digital channels. Plugging in a digital tuner would work, but is unnecessary. What you probably have to do is run the 'auto scan' feature through the recorders menu. Hit "Home" button go to the "TV" icon and select "Auto Scan". It will take a few minutes, but recorder will scan for digital channels and memorize them.
