Question about Dryers
KENMORE DRYER STOPPED BLOWING HOT AIR.
  • 7 more comments
  • camsamgrud Nov 15, 2007
    My electric kenmore dryer stopped blowing hot air but works otherwise.
  • Anonymous Apr 21, 2008
    dryer works but does not blow hot air
    how do i get to the fuse?
  • Anonymous May 19, 2008
    i have problems with my kenmore 80 series the motor runs perfect but it doesn't heat up
  • Anonymous Jul 07, 2008
    My C85072 dryer has same problem. How can I fix it?
  • costanzi99 Jul 24, 2008
    my dryer turns but no heat help i have the kenmore dryer c85072 does this model have a thermo built in it or can it be just the element thats burnt out [email protected]
  • cloria Jan 16, 2009
    I too have this Kenmore model C85072 dryer, and it too doesn't dry my clothes.
  • pobmc Jan 29, 2009
    I have a Kenmore 400 series Electric dryer that will not heat up and is making a rumbling noise.
    I also need a diagram of this particular dryer.
  • jslinder Apr 02, 2009
    The Kenmore dryer that I have is also not heating. It runs ok but will not dry anything. have been told that it is the heating element. How can I find out for sure, and get the part I need?
  • Anonymous May 03, 2009
    i have a kenmore dryer that will not dry the clothes, but it run just fine
Have the C85072 Kenmore electric dryer also work otherwise but does not blow hot air
Posted on Jan 27, 2008
Kenmore dryer is not heating having problems accessing the back panel as it is welded on. How are you supose to get to the parts if the back is welded?
Posted on Aug 30, 2008
  • 625 Answers
Electric or gas?
Posted on Sep 13, 2007
SOURCE:
I have a kenmore 110.87561601 dryer, it blows warm air but not hot, is this the norm for it?
Check power at the outlet. If you're not getting the full 240v then it'll come out warm but not hot. Otherwise I would go with the timer.
Oct 01, 2014 | Kenmore Dryers
My Kenmore 400 series dryer has stop blowing hot air to dry my clothes. It blows room temperature air therefore, my clothes don't dry in a timely manner. How do I fix this problem? Thanks,
Hi Most ahve the same problem, maybe the dryer vent is plugged up , pull unit out and unplug it , remove vent and clean , then with a tester check over heat sensors at rear of dryer , they knid of look like diodes with two wires going to them , you could also by pass them with a jumper wire , BUT JUST TO TEST THEM ONLY ! it could also be th eelement , but most times it is a sensor form over heating unit , both are very cheep to fix,
Jul 27, 2011 | Kenmore 400 6942 Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
My dryer runs but has no hot air and won't turn itself off.
you might need to replace the heating element
Sep 05, 2009 | Kenmore 63942 Dryer
MY DRYER GETS HOT ON TOP OF THE DRYER (KENMORE) COULD IT BE THE VENT?
start dryer, go outside and see if vent is blowing hot air. If not then vent is clogged with lint, esp if vent has a curve or elbow in it. unhook vent at dryer or os vent and run a vacumn hose in as far as you can. easy way to determine if vent is to unhook at dryer and see if dryer blows air, could be just inside at vent opening
Jul 11, 2009 | Kenmore Dryers
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Dryer not blowing hot air
you either have bad element or bad thermo disk or thermo fuse
Jul 01, 2009 | Kenmore 63942 Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
My dryer is ot blowing hot air
Remove the heater vent, then turn dryer on. Does this fix problem? If so then you have a block in your vent hose.
Dec 31, 2008 | Kenmore 75962 Gas Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
782 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
