Question about RCA P56950 56" Rear Projection Television
RCA ctc 195 series
When i plug it in the tv makes a beep noise and does nothing else
  • Anonymous Apr 30, 2008
    I have the same problem with the tv not turning on and making the beeping noise. Is this a fixable problem? It went out while watching it, we heard a big pop..
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
This tv most likely has a shorted horizontal transistor and transformer. Now that you have a heads up on the problem it's best to contact your local tv rep. John
Posted on Sep 18, 2007
SOURCE:
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Beeps
OK Replace FBT #239111 Flyback transfomer and Hori output NTE2324 (((((((FBT 22.95 -- ACME 1-800-575-9833 1yr warranty on theres.
Dec 28, 2008 | Televison & Video
White noise
Unplug the set for 2 minutes and then trying again.
Jul 31, 2008 | Televison & Video
CTC 195 series
Horizontal output transistor is needing replacement for sure and quite possibly the flyback as well
Jun 29, 2008 | RCA P56950 56" Rear Projection Television
Rca 52" ctc 195 series, model p52926
I would take it to a repair shop, they charge around $50 to look it over, and then tell you want is wrong with it and they will give you the cost to fix it. This is what I do when TV's go out. It will save you time and money in the long run.
May 19, 2008 | RCA P52926 52" Rear Projection Television
Ctc 195 sereis tv
Try unplugging your set, If you didnt save the changes this should reset it back to default settings. If that desnt work, you will need to go bak into the service manual and adjust the horizontal size. Just write down anything you change so you can revert back if you have too.
Jan 22, 2008 | RCA P56950 56" Rear Projection Television
RCA P61927 NO POWER!!! HELP
If it is a ctc or ptk 195 then you have a bad flyback High Voltage transformer: the large white kindof square thing with big red wire coming out; Must get original RCA part. If picture was good before could cost you a total of (average) $300.00 according to which repairman.
Dec 14, 2007 | RCA P61927 61" Rear Projection Television
Rca p52927 chassis ptk 195 wont power up all of a sudden
ctc chassis with the 195 chassis were famous for flyback transformer shorting and taking out the horizontal output transistor also.
Oct 24, 2007 | RCA P52937 52" Rear Projection Television
Rca ctc 195 series
Before anyone changes those setings you should write them down.
Apr 15, 2007 | RCA P56950 56" Rear Projection Television
RCA P56950 56" Rear Projection Television Logo
112 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
