Question about RCA HD52W58 52" TV
No sound for cable connection but through dvd,there is sound
My supra 21" TV doesn't have sound when in use through cable connection, but there is picture, however if we use through dvd, there is sound.
  • 2 more comments
  • djrose_29 Apr 14, 2009
    the cable connects directly to the tv
  • djrose_29 Apr 15, 2009
    yes,that's true the sound comes through normally watching dvd...but through cable, still no sound but there is a clear picture.
  • May 11, 2010
    OK, that wasn't the answer I'd hoped for. One more question. The DVD player is hooked to one of the set's a/v inputs, and you switch to that input to watch a DVD, and the sound comes through normally?
  • May 11, 2010
    Are you using a cable converter box or does the cable connect directly to the TV?
    President:
  • 2,992 Answers
Since the set will give sound from a DVD, at least the TV's audio amplifier is working. I'm ready to say you have a bad tuner, but I'm not absolutely certain. There may be trouble in the TV's audio processing stages. Or you could have something set wrong.
First, check the TV settings to be sure you have it set for the right tuning system and that the audio is set for normal. If the settings are right, try tuning in something besides the cable. If you have a VCR with RF output (that is, one that outputs on channel 3 or 4), hook that up and check for normal sound on that channel. If there is still no sound, your TV is at fault and would need service.
Posted on Apr 15, 2009
Connect sony dvd player to the tv
To connect any DVD player to any TV you need AV cables or a 21 scart .
Oct 08, 2016 | Hisense Televison & Video
Need to hook up sayo sound bar to my elment tv and my dvd player together
Help me connect my soundbar to TV, DVD, and Cable ...
www.tomsguide.com/answers/id.../connecting-soundbar-dvd-cable.html
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and cable box. ... More about : connecting soundbar dvd cable ... SolvedHow do I connectmy Element ELEFW392 TV to my Insignia NS-SB314 soundbar.
How do I connect my sound bar to the TV, BluRay, DVD, and ...
www.tomsguide.com/answers/.../connect-sound-bar-bluray-dvd-dish.htm...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... pretty hook them up and it works' followed by 'why did you buy a sound bar?' Do Ihave to connect sound bar to TV AND Dish receiver? and not to DVD? ... tv bluraysound bar and a DVR cable box together Forum; Solvedconnecting ...
Soundbar to tv [Solved] - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2198401/soundbar.html
Jan 11, 2016 | Televison & Video
No to hook sound bar to element TV and my DVD player at the same time
Jan 2, 2015 - I want to connect my soundbar to give sound from my dvd player and... The soundbar has an optical cable option, but my tv does not support that cable. ...SolvedHow do I connect my Element ELEFW392 TV to my Insignia ...
Dec 30, 2014 - Then connected Panasonic Blu Ray DVD player: Panasonic HDMI to TV... first time, that paired the sound bar to the subwoofer but still no sound. ... Do I have to connect sound bar to TV AND Dish receiver? and not to DVD?
Jan 11, 2016 | Sanyo Televison & Video
TV MODEL 2168B DISPLAYS DVD FILM IN BLACK/WHITE..WHY?
If it's connected via SCART, check the cable is connected both sides. If this doesn't fix the problem, try a different cable. If this still doesn't fix it, it will be a fault with your dvd player.
Jun 10, 2011 | Televison & Video
My dvd player and tv blink on and off . When the dvd is unplugged the tv is ok? Whats the problem?
It sounds like your DVD player is the problem, not the TV. Check all the connections from the DVD to the TV and the power cord to the DVD and make sure they are all connected correctly and tightly. If that doesn't help try replacing the cables connecting the DVD to the TV. After that try using a different kind of connection (switch from S-Video to composite or component, or vice versa). If none of that works, the DVD player may be bad. Most of the time it isn't worth having it looked at for repair.
May 22, 2011 | Televison & Video
When u put a dvd in it shows coloured,but regular tv channels shows black and white
Most likely the cable between the cable/satellite box and the tv is not fully home. Push all the connections firmly home and try it again.
May 03, 2011 | Televison & Video
We have a black and white picture on the TV, no colour
check for DVD/TV cable. Use a SCART 21 conductor cable (if possible with gold contacts), or HDMI Cable if Tv has HDMI Input
Nov 29, 2009 | Panasonic DVD-S35 DVD Player
I have connected my Bush DS-A332B dvd player to my Sharp Aquos 32GD8E 32 inch flat screen TV with a Bush HDMI cable (26602BU) but can only get sound and no picture. The cable is slotted into Ext 5 yet when...
I have same problem sound but no picture, have tried it on 2 different tv's but no luck, have tried 2 different hdmi leads (both Bush 26602bu) but no luck. I even thought it was the port on my tv but it works fine with another dvd player and the same lead. I even returned the dvd player and exchanged it, still the same... It's driving me nuts...
Help please......
Sep 14, 2009 | Televison & Video
Dvd player connection to tv
possible reason could be:the cables are corrected wrongly,if you use RCA type please ensure the color coding is correct and are firmly in place..
Nov 06, 2008 | Sharp 21" Multi System Stereo TV
Mintek MDP-1070
A component lead comprises of 5 phono plugs 3 for pic red and white for sound. If your TV has progressive scan it must have an HDMI connection if so and the MDP also has one that is a better way to connect it.
Jan 17, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
RCA HD52W58 52" TV Logo
134 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
