Question about Ovens
I have a 30" GE wall oven JTP14WV1WW that I can't regulate temp or set clock. On expert advice I replaced control panel. It did not resolve the problem. Would you think replacing the circuit board be the next thing?
  • racrdy Apr 15, 2009
    Hi Kevin
    I'll try the circuit board and let you know what happens. To bad that this is such a shot in the dark.
    Thanks again,
    racrdy
    Yes
    Genius:
  • 1,847 Answers
Yes that would be right, there was a chance that control panel might me bad, but as you have already changed it. changing the circuit board should resolve the issue. I don't seem the problem else where as.
Let me know the status
Kevin
Posted on Apr 14, 2009
Hi. When you turn on the top oven the upper element doesn't shut off after it gets to the set temp.
It could be a stuck or welded relay in the control board. Sometimes a sharp rap on the relays on the control board will jar the contacts loose. Be careful not to tap too hard and make sure the power is off. If this doesn't solve the problem you may have to replace the control board.
Mar 28, 2014 | Maytag MEW6630DDB Electric 30 in Double...
Control panel flashes F7
The F7 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F7 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Oct 02, 2011 | GE 30" Built-In Single Electric Wall Oven...
My GE wall Oven Model #jctp18ba1bb is not working.the board is blankm the only thing that works is the oven light.Is there any kind of thermal fuses etc. in this oven.thge control board was replaced 8...
When you say board I assume you mean the electronic clock/timer. This timer directly affects the oven operation. Even if the internal oven fuse is blown or the thermal overload is tripped the electronic timer and oven light will always work. If the oven light works and the electronic timer/clock does not I'd say that the timer/clock is faulty.
Feb 10, 2011 | GE Profile 30" Built-In Single Electric...
30 " Convection wall oven
F2 During BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN C ontrol senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Nov 26, 2010 | GE 27" Built-In Double Electric Convection...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
We had a power outage and the oven will not work, after shutting off the power the panel lit up with all 8888s and will not work
Forgive me for saying this, turn the unit off wait 30seconds, then turn on again (this sometimes works)
There is a very good possibility you have suffered a power surge which has damaged your electronics unit. Please check your manual to see if there is a reset button on the display (this sometimes reolves it).
If there is no way to reset, then you will need to replace the displat/circuit board, this is quite fiddly and i would recommend you call in an appliance expert.
I hope this helps.
Jul 08, 2009 | GE PT956CMCC Profile 30" Built-In Double...
GE Wall Oven JKP70 Locks and reads F9
From all the information I could gather on this issue, including speaking with a GE tech I decided to call in a repair person.
Dec 29, 2008 | GE JTP20 Electric Single Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
41 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
