Question about Nintendo Game Boy Advance Console
Programming garage door opener
I have a "ultra lift" garage goor opener but i don't have the instructions to program the remote. it is made by "moore-o-matic" or "linear" model 700S serial no 920710238 is there a web site where you can download instructions?
  • Anonymous Apr 01, 2009
    I am trying to program my Toyota to operate a Moore-O-Matic 700-S. I am trying to locate the Learn button. Where is it located?
  • Anonymous Mar 17, 2014
    Moore o matic garage door won't open. The operating motor runs.
  • 57 Answers
Http:// 1rst is to purchase the second is a manual index.
Posted on Sep 13, 2007
Programming remote and in car garage door openers to the Craftsman AssureLink Garage Door opener - Model - 139.3043
The opener radio is not compatible with your homelink system. You need to buy a homelink repeater. Note: liftmaster and chaimberlain are the same, so if you see a reference to one of those names when searching for the repeater, dont worry, it'll work. As far as the second remote, check batteries. Then try programing again, using yellow button on the opener. Lastly, you can reset the programming and start over if all else fails. Hold down yellow button until light on button turns off. Good luck.
Nov 02, 2014 | Craftsman AssureLink Garage Door Opener...
How do i program remote in a 2012 crosstour for garage door?
Google the brand name and model, instruction will be found.
Apr 21, 2014 | Honda 2012 Crosstour EX-L
How to program garage door remote
Check the manufacturer's web site for manual and instructions.
Feb 22, 2014 | Televison & Video
How do I program the garage door opener?
You post again, what the model is of the opener, the car model, it looks like this control is in a car.
Most times you need the garage door remote, then you have to hold a button and the remote button to sync the two.
What ever you are trying to program, if this is a car, you need the manual.
If you need more help, you need to post the model number of everything.
Not every car, every opener is the same at programing.
Imagine that, life simple.
Apr 03, 2013 | Building Materials
There was a minor change for mine to work.. see below..
- you must park your Prius close to the gate opener, leaving it running (obviously not in the way of the gate closing)
- Hold the button the the mirror and then push your garage door remote button and hold until the light on the mirror starts to flasyh fast. THIS programs the button on the mirror, but not the garage opener - yet (this was key for me)
- locate the "learning button" on the opener itself
- press the "learning button" on your gate opener and then get back into the Prius within 30 seconds (more time than it sounds) and press the SAME Homelink button you just programmed above. I don't recall how long I held the pre-programmed button, but the light will flash as I recall.
- Then, when working the garage door, you may need to hold the mirror button for a good second for it to work - but I had tried for months to get mine to work, and finally after reading many posts, the above sequence worked on my 2008 Prius with my Lift Master, Security + rolling codes garage opener.
Just - program the button on the mirror with your remote FIRST.. the garage opener will not work.. then use the Learn button on the garage opener and the SAME BUTTON you just programmed.. and it worked great for me. Not programming the mirror button first will not work. Using only the Learn button will not work. You must program the mirror first with the remote, then use the learn button and the SAME button on the mirror. Hope this helps.
Scott 2008 Prius with Lift Master Security + opener.
Oct 30, 2009 | 2007 Toyota Prius
Programming car remote using garage door opener remote control fo
Jul 03, 2009 | 2003 Lexus ES 300
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
I can not hook up Honda odissy 2007 Homelink system with LiftMast
Yes. But you need a remote transmitter that is programmed to open the Lift Master. Then you just follow the instructions in your home link and it should work.
Press the homelink outside 2 button at the same time and hold till fast blinking (all erased). Then press homelink button1 and hold while aiming the transmitter (2 inches away) and pressing appropriate button on the remote. Continue to hold both till fast flashing seed on the homelink. Release both. Then hold the next button on the homelink you want to program, aiming the remote again, and pressing and holding the appropriate button on the remote, until fast flashing, and then releasing again, ......
Feb 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener
I was having a problem with the remotes. Program one remote, and the other stops working and vice-versa. I found the solution to be as follows: Using 61LM single-button remotes for Lift-master WhisperDrive (belt drive) garage door opener, I set the dipswitches (find them by removing battery replacement cover) to identical settings in both remotes. Set the first dipswitch to the neutral (0) setting. Next -- and this is the important part -- press the learn button on the main door opening unit, and, while the small LED light is lit, press the button on ONE of the remotes. DO NOT REPEAT ON THE SECOND REMOTE. Upon doing this, I found that BOTH remotes at last worked. I then went on to program a keyless entry pad, which was accomplished by again pressing the learn button on the main unit, and then entering the number sequence I had chosen for my entry code on the keypad, and pressing Enter. Both remotes continued to function and the keypad functions as well.
Mar 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Nintendo Game Boy Advance Console Logo
1,441 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
