Question about Sony PlayStation 2 (PS2) Console
PS2 is on, but no signal
Ok so my little sister dropped my ps2 on saturday... know the ps2 wont open the game drive...i cant change games it just wont open it does turn on...but i also dont get signal on my tv...all i see is the green light that indicates that the ps2 is on.. i dont know what to do
    Genius:
  • 1,139 Answers
I think I know what happened, when the PS2 hit the ground, it may have detached the internal module that allows you to connect to the TV namely the modulator board or the RCA jacks. The circuit board may even have been cracked. Ok first I am assuming that you are under 18, and if you are there is no way I am going to tell you to open up a piece of electronic equipment to affect repairs on it. Now if you are into electronic repairs or learning electronics I would tell you to open up the unit look for the damaged area, draw out the traces that seem to be broken and jumper them, the problem is PS2 and other gaming syatems use a multi-layed board so some of the traces might be internal to the board itself. So what I'll say to you is open up the unit and if there is too much damage take the unit to an authorized electronics shop that specializes in game consoles and have them repair or replace the circuit board. I hope this helps.
Posted on Sep 13, 2007
  • 752 Answers
The tray has become misalligned. If you want to fix it on your own heres what you do. Remove the 6 (or 8 depending on generation) screws on the bottom. Remove the warranty sticker on the back by the power switch. With the front towards you, lift the top while tilting slightly toward the front and pivoting it by the power/eject buttons. Either remove the button assembly by popping it off the lid or just be careful not to tear the cable. Remove 4 philips screws from the cd mech lid and lift off. Remove two philips screws from the tray hinge. Lift and slide tray out of front. Push white gear frame at front of tray area to the right and hold it there while you put the tray back in. Reassembly is reverse of disassembly.
My sister bump me into my xbox 360 and a game was
replace the game since it most likely was ground up by the disk drive. I had a PS2 do this to me and the game was demolished.
Apr 25, 2010 | Microsoft Xbox 360 Console
My PS2 has stopped working!!!
spindle motor went bad it sounds like. Open up the ps2 and inside of there, you'll see a ribbon for the drive, take it off of the board and then reseat it.
Now put the top back on and try the drive again. If it still doesn't spin then the drive will need to be replaced.
Jan 06, 2010 | Sony PlayStation 2 Slimline Console
What software can i use to play files from my flash drive using a ps2? Can i use Action replay or codebreaker or any other software?
well i would have to say that playing a game from a usb drive is not dependable, think about this for a second. The playstation 2 would have to somehow read the files on the usb drive, but then also take information off the drive to run the game. that usb port wont handle that much data, its just not possible to have ur ps2 trying to run a file on something that can only send so much data to it. Even a HardMOD[ meaning a chip is installed physicaly] its still hard to imagine someone trying to make that possible, but see if you have a Big ps2 then a hardrive is the only option, see the old ps2s were supposed to have a harddrive option but it endded up being a part of a game FFXI, so if you have a hardrive for the ps2 then you simply SoftMod it[ Software that mods the ps2 either threw the gamegenie or codebreaker and other programs, but the new ones dont have that option of a harddrive and if you have one you are out of luck using a harddrive as storage, but there is something called disc swapping.
see when you open ur ps2 tray theirs three or two buttons inside the slim ps2 that tell the ps2 when the dvd tray is open and thus it wont read a game till you close it.
but by tapping those key buttons down{ google how to do this,] you can burn a ps2 game and then with one legit ps2 game you first use the legit game and let it read then swap out the legit with any burned game and then one more swap and it allows you two play any burned game with just one legit game
http://www.youtube.com/watch?v=RimA3ZzIBEs heres for a phat ps2
http://www.youtube.com/watch?v=o7x5JItxJCE&feature=related more detail and also when you downlaod iso's u use a burnig tool to put it on a dvd, and yes you dont need the original game.
Oct 28, 2009 | Sony PlayStation 2 (PS2) Console
My ps2 has a problem reading certain games but works with others
The PS2 has always had trouble with certain discs. And yes you can often tell by the "color". RE4 although from ancient was pre PS3 and basically some of the newer games wont work on the "old" PS2's as well. Partially due to the fact they are a bit dirtier and worn out and cant read the faster speeds as well. You might want to consider purchasing a "new" PS2 ($99) that wont have the same problem.
Jun 12, 2009 | Sony PlayStation 2 (PS2) Console
PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
My ps3 wont run ps2 games
The reason why ur ps3 40gb wont run ps2 games is because its only a 40gb. If u had a 80gb ps3 then u could play ps2 games.
Dec 20, 2008 | Sony PlayStation 3 40GB System
My ps2 wont turn on
Droped it , now your screwed
Nov 15, 2008 | Sony PlayStation 2 (PS2) Console
My 60 GB PS3 wont run PS2 games
Actually only 60GB PS3s supports PS2 games. But It requires particular firmware. In first instance try updating your system, then dissable the disc autoload function, insert PS2 game, and look at the game section if your soft will recognise it. If yes just try to play
Good luck
Aug 07, 2008 | Sony Playstation 3 (PS3) Console
System dropped
there will be a problem with the circuitry see if you can find a gaming repair shop, they will have it up and running in no time
Apr 13, 2008 | Sony PlayStation 2 (PS2) Console
Disc read error for PS2 games
Hi Bunny,
Ur PS2 optical getting weaker and it needs service.Contact any expert for its service,And dont try to do it personally if u dont know about it.
Dec 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
