Question about Zanussi ZWF1020 Front Load Washer
Crackling noise from washing machine
Our wasing machine has started to make a crackling sound when on a normal wash cycle. The noise stops once the machine starts to spin. Everything seems to be working fine and we have checked the drum and filter. Any ideas gratefully received! Thank you.
4 Suggested Answers
  • 958 Answers
SOURCE: washing machine making crackling noise when spinning
check for some loose items underneath the unit. washing machines normally reverses its rotation when spinning. check if mechanical solenoids pulls the right levers as it starts to spin....
Posted on Feb 12, 2008
  • 193 Answers
SOURCE: Washing machine not working
motor bearings and or motor
Posted on Apr 29, 2010
  • 6277 Answers
SOURCE: Zanussi ZWF 1020W front loading
Hi from retired Englishman in SW France @ 21:17 Sat evening,
I presume that you could turn the drum by hand? Also how old/used is it, please?
Can you hear a sound as if the motor is turning? If you can it could be that the belt has broken/come off. If you cannot hear it it could be that the motor is not working.
WITH THE POWER OFF-
have the back removed so that the belt (and motor) can then be seen easily.
If belt is OK then it is likely to be the motor especially if the machine is quite a few years old and well used. Often the motor brushes wear down to the extent that they do not run on the commutator and the motor stops- or, as in our case just before Xmas, becomes intermittent. Although it is possible to go the least costly way and have the brushes changed, it is false economy in the long run. The new brushes will not bed in correctly and will only last a fairly short time (I've heard of 1 month!). A replacement motor (ours cost £250- and I replaced the belt at the same time- both were 15-20 years old) should last for many years.
I hope this assists,
Cheers,
John C
Posted on Jan 29, 2011
I have a lg top loader washing machine model:wf-t1391tp when wasing and rinsing it makes a huge grinding and crackling sound like is going to brake something underneath motor or gearbox.
Check whether the inner rotating drum is contacting the stationary tub.
The other problems that cause this condition is the clutch assembly and or the motor drive system.
Check both assemblies for security and free movement of rotating parts.
Check also the tub supporting dampers for condition.
Feb 23, 2016 | LG Washing Machines
Wma 33 started making a crackling noise on cycle
Crackling noise could well be due to worn motor brushes,they are simple to fit and cost about £15 per set to buy, good luck
Jul 04, 2011 | Hotpoint Washing Machines
My Kenmore dishwasher makes an intermittent crackling noise during one of the cycles!
The crackling noise is something caught in the pump housing area. This may eventually wash out but usually disassembly is reguired.
Feb 24, 2010 | Dishwashers
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
Running a heavy load; stopped during rinse cycle; won't drain or spin;
There may be something stuck in the pump, did you hear a buzzing or crackling noise?
Jun 19, 2009 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
May 27, 2009 | Roper RAX7244KQ Top Load Washer
LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Feb 10, 2009 | LG WM2432H Front Load Washing Machine
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
Washing machine making crackling noise when spinning
Feb 12, 2008 | Ariston Technologies AWD120 13 lb. Washer...
Zanussi ZWF1020 Front Load Washer Logo
240 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
