Question about Dell Inspiron 6400 Notebook
Can i replace internal hard drive with 320 scorpio in dell 6400
    Scholar:
  • 113 Answers
Hi welcome to fixya!
yes you can use 320 hdd scorpio as your internal drive for replacement to the older hdd drive of your dell 6400
Posted on Apr 14, 2009
I have three RD1000 catridges that are bad. Can I replace the Sata drive in the catridge with another 2.5 sata drive? How do I format the new drive?
Yes, no problem. But test the ones you have now before that - to make sure the disks are the ones that failed and not the board of the cartridge.
Jun 24, 2011 | DELL PowerVault RD1000 SATA Internal Disk...
Hardisk not detected
- Check hard drive connection (SATA cable).
- Check Bios Setup (hard drive configuration - SATA drive should be enabled)
May 16, 2011 | Western Digital WD Scorpio WD3200BEVT hard...
HARD DISK NO OPEN
Hard disk shouldn't be opened. They are air tight beacuse dust getting in there could break the whole hard drive.
Mar 05, 2011 | Western Digital WD Scorpio Blue WD3200BPVT...
I am trying to install a WD3200BEVE hard drive into a Dell Inspiron 6000 and it reads "Internal HDD Error" I received this hard drive from Dell after my previous hard drive WD600 went bad. Do I...
It's possible that the only problem is that the replacement disk-drive needs to be "initialized" for first-time usage. Or, it's possible that your Dell won't support your new _larger_ disk-drive.
Did they send you a disk-drive with _greater_ capacity than your old 60GB drive?
It's possible that they "upgraded" you, because they had no (small) 60GB disk-drives in inventory.
Take your Dell "System Restore" set of CD/DVD disks, and reinstall Windows.
The Windows Installer will "initialize" your disk-drive.
Dec 18, 2010 | Western Digital Scorpio WD600VE 60 GB Hard...
INSTALL DISK 320 GB IN THE DELL BIOS does not show ISPIRON 6400
The biggest drive that was offered with that was a 120gb. So you should be ok as far as the 320 size. I did a 80 to a 320 and it worked. There shouldn;t be any jumpers to set on the drive. So I would check the power connector if it is seperate. You should hear or feel the drive spin up even if it isn't detected. The next thing is to check the bios and see if it is detected. That might be all it takes is to open the bios and force it to detect the drive instead of auto.
You may need to do a bios update.
Aug 13, 2010 | Dell Inspiron 6400 Notebook
Hi I got a Dell Inspiron 6400 laptop. The current HHD is the seagate momentus 5400.3 120g. This is now damaged. Can I use the Seagate Momentus 5400.6, 320 G, 5400 RPM SATA2. Will my laptop support the 320g...
Hello: I see no problem using a bigger harddrive in the unit,the only concern I think you might have is to purchase a hard drive caddy for the interface, Especially if the current hard drive is an IDE Interface, You can purchase a IDE to Sata Interface caddy, to support the drive Interface if it's an IDE format. You might want to check with Dell for compatibility first before purchasing the Sata Drive.
Nov 30, 2009 | Dell Inspiron 6400 Notebook
I am using SuperDuper to clone my 160GB MacBook Hard Drive to a 500GB Western Digital Scorpio Blue. My problem is that I cannot determine why neither the SuperDuper program nor the MacBook itself...
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
Oct 24, 2009 | Western Digital Elements powered by WD 320...
as long as its the correct physical size in terms of dimensions and its the correct connector type ie SATA, PATA then it should be fine.
If its IDE you will need to check the jumpers are set correctly
Apr 14, 2009 | Computers & Internet
WD Scorpio Black 320GB SATA drive
Halarious, I had the same problem yet I used norton ghost. At least you still show 160 gb. Mine went all the way to 60 gb. Here is what I had to do to reclaim the lost. I downloaded something called "Magic Boot Disk" It gave me the whole 320 back yet have not found good cloning software yet. Magic Boot Disc is freeware avaliable at http://hddguru.com/content/en/software/2006.02.10-Magic-Boot-Disk/ Good luck cloning
Feb 21, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Dell Inspiron 6400 Notebook Logo
155 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
