Question about Brother MFC-5840CN All-In-One InkJet Printer
Init unable AF
The printer has a grinding sound it seemly is trying to move the scan bar but can't.then it display the message init unable
  • 3 more comments
  • Anonymous Mar 17, 2014
    my brother mfc-825 printer is reading Unable to Init. AF
  • Anonymous Mar 22, 2014
    Displays error message and makes a rattling noise as if trying to connect to something.
  • Anonymous Mar 25, 2014
    unable to print init.af
    What does this means machine err0r 50 and Init Unable 50?
    Unable to print, photocopy, scan, ink blot and etc
  • 832 Answers
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Posted on Sep 13, 2007
  • 3 more comments
  • Michal Knoller Jan 20, 2014
    That didn't help and now my error changed to "machine error AF" (I have the entire cover and disconnected) -
    I'm considering taking off the entire body to check the whole path of the print head, but I did that last night and it didn't help
  • isagani Diaz
    isagani Diaz Jul 18, 2015
    I have the same problem "Init Unable AF".I tried to replace the whole scanner but the problem still there. Anybody who had found a solution, pls reply. Thanks
  • Hari Tharu
    Hari Tharu Nov 24, 2016
    Init Unable AF, I have same problem but the cable is true position
  • Hari Tharu
    Thank-you for help, your status is 100 % Right.My printers problems is solve.
I've broken the flat cable right at the connector on the main PCB. The behavior is exactly as described. I suggest others to look carefully at this cable when having this issue.
Now if I can only figure out how to repair/replace this cable???
Posted on Sep 10, 2017
    New Friend:
It helpd me thank you! I only just check the both ends of the flat cable and i found out one end of it has broken conductor then i cut a new one:)it works.
Posted on Nov 06, 2014
    New Friend:
  • 38 Answers
I got that problem too but solve, i check the gear and belting.. there something missing like gear torn broke and some dirt or similar blocking its track.. you better check coz to its some kind of mechanical problem not software.. hope this solve the prob..
Posted on Jun 13, 2013
    I opened the entire printer - the print head seems to slide and trigger the right side - how do I know if what i think is right actually is?
I m sorry but i tries everything but it is still doing the same thing
Posted on Jan 23, 2008
    New Friend:
No it makes grinding noise with a beep sound then scan unable af is displayed
Posted on Nov 21, 2012
SOURCE:
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
Unable to clean 5a
Sir/Madam
If one of the following messages is displayed on Your Printer,I suggest You Go To Below Official Brother Website For Troubleshooting,
  • Unable to Clean (Clean Unable)
  • Unable to Init. (Init Unable)
  • Unable to Print (Print Unable)
  • Unable to Scan (Scan Unable)
http://welcome.solutions.brother.com/BSC/public/as/sg/en/faq/faq/000000/000500/000065/faq000565_012.html?reg=as&c=sg&lang=en&prod=mfc290c_all
Or If You FaceProble Then Follows Us On For Online
Brother Printer Support
Jan 08, 2014 | Brother MFC-465CN InkJet Printer
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
Unable to Init AF - New printer!
sure (this advice costs you some greetings from me to the beloved bahamas ;-))
you have to open the scanner as you have done to connect the usb cable. When opened you can see a "z" like small cover going from panel to the right rear side.
Open this cover which hides the flat cable of the scanner. The cable needs reconnecting to the main board. Simply stick it carefully into the right positon.
(will post a picture later)
Apr 04, 2008 | Brother MFC-465CN InkJet Printer
Brother MFC-240C init. unable AF error message
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Dec 12, 2007 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
9,924 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
