Shows white screen when it is on stand by mode
Note bookAcer Extensa 5630 shows white screen when it is on stand by mode
Part no. for 15.4'' WXGA LCD to suite acer extensa 5630
hello
If your original LCD Screen Resolution is more than 1024x768, Please don't use this
this LCD is worth about $100
Brand: LG.PHILIPS
Part Number LP154WX2
Size 15.4-inch Screen (13.1"x8.2")
Resolution WXGA (1280x800)
Surface Matte
Aspect Ratio Standard
Backlight Type CCFL 1-Bulb
Backlight Connector 2 pins Backlight Connector
Video Signal Connector 30 pins Video Connector
hope i served you well
Nov 05, 2010 | Acer Extensa 5630-6806 Notebook
Acer extensa 5630 laptop. my crystal eye wcam doesnt work on windows 7 operating system. anybody can help?
You need to locate a set of Windows 7 drivers, By your post I assume you upgraded from a previous version of windows. These drivers will have to be provided by the camera Manufacturer or Acer. You might possibly be able to get it working by setting Win 7 to run that device in Compatibility mode.
Jul 04, 2010 | Acer Extensa 5630-6806 Notebook
My Nokia 5630 XpressMusic hangs up while starting, showing a white screen with nokia logo. what can i do ?
tray to formatting with your finger. the way is press *+3+send button and power on your phone and do not relaease your finger for a while. note:it must press togather.
May 18, 2010 | Nokia 5630 XpressMusic Smartphone
Have no sound, think i need the sound driver for
HI,
You can go to device manager and right click on screen and select scan for hardware changes,
It will detect hardware after that asked you for driver put the driver in CD/DVD ROM and continue instruction
Hope it can resolved your issue,please revert back for further support
Thanks for using Fixya
Apr 04, 2010 | Acer Extensa 5630-6806 Notebook
Cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Feb 19, 2010 | Acer Computers & Internet
Blue screen on acer extensa 5630 laptop it says its my intel display driver
Try rebooting the computer in safe mode with networking...this is usually done by tapping the F8 key while the manufacturers splash screen shows up for a few seconds. Once the multi-boot screen comes up scroll to safe mode with networking and click ok. Once the computer boots up, it will probably be using a generic video driver to show a picture, go to acer's support site and download a fresh driver, the link is below....good luck. when you click the link, make sure you pick what operating system you are using to get the correct driver. click on drivers > notebook > aspire > 5630 > choose operating system.
http://gd.panam.acer.com/home/
Oct 07, 2009 | Computers & Internet
Won't boot up on first try
Whenever you do get it booted into windows, run the command prompt and in there run "chkdsk /f". That will check your disk for errors and repair them. Yours sounds like a boot sector problem, chkdsk should be able to fix that.
Jul 24, 2009 | Acer Extensa 5630-6806 Notebook
The screen shows vertical line on a white background then when i adjust the screen, it turns completely white. But for me it is when adjusting or applying a small pressure on the screen or even when...
The screen is starting to go bad and needs to be replaced probably. Anytime lines appear it usually means the screen is bad.
Best way to verify this, is to unseat and reseat the lcd cables to the screen and if it still happens then you know the screen is bad, if it doesn't then it was a loose cable.
Jul 06, 2009 | Acer Extensa 5630-6806 Notebook
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
Screen on my extensa 5630 laptop shows nothing but verticle lines
I had to finally send the machine to ACER and it was a hardware problem; they have to change the cable linking the display with the MB
Mar 22, 2009 | Acer Extensa 5630-6806 Notebook
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
