Home | Dishwashers | Dishwasher not cleaning
Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
By Va1kyrie on Sep 13, 2007
Over the past 2 weeks, my cups have a sand like substance in them. I have hand washed every item before loading and even changed brand of dishwashing detergent. I then took out the screen in the bottom and cleaning it. It is still happening...help!
I have frigidaire professional series dishwasher
Comments:
Sep 18, 2007
- hi thank you for your suggestions. Yes i did change my detergent and also the rinse aid is full.
I have no idea what washing machine salt is. So i have not tried this. Could you please explain in more detail what it is, where i buy it and how to use it?
Thanks!
Sep 23, 2007
- thank you everyone for you your help. putting the dishwasher salt in actually helped the first time! i appreciate all of your help.
Same Problem
Oct 04, 2008
-   sandy residue after washing expecially on top tray and more at the front of machine -   Guest
Jun 23, 2008
-   Over the past 4 weeks, my cups have a sand like substance in them. I have hand washed every item before loading and even changed brand of dishwashing detergent. It is still happening...help! I have a Whirlpool Quiet Partner I.I use rinse aid and evrything.-   orimax
May 10, 2008
-   When I start my dishwasher, it fills, then drains......but I get no second water. What can I do?-   swailo
Mar 13, 2008
-   the dishes on the top rack won't come clean, just started this a week or so ago. Iv'e taken the rack out to make sure there's nothing stuck in the tube, it's clean, any other idea's?-   jimang
Nov 14, 2007
-   White Powder Residue on dishes after wash is complete.-   JWoodBass
Best Solution
posted on Jun 20, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
MY MAYTAG QUIET SERIES 300 DISHWASHER DOES NOT COMPLETELY DRAIN WHEN WASH CYCLE IS COMPLETE-OTHERS HAVE SUGGESTED VINEGAR & CALCIUM BUILD-UP---WHAT SHOULD i TRY?
Solution #2
posted on Sep 14, 2007
Very Helpful)
El Rico
Rank: Guide
Rating: 87%, 11 votes
Lack of salt in the dispenser !
It needs topping up !
It will take a couple of washes for the system to get itself back to normal.
Was this helpful?
Yes
No
Solution #3
posted on Sep 13, 2007
Very Helpful)
dovi
Rank: Guru
Rating: 88%, 2492 votes
Some questions:
- Did you changed your detergent to a new one?
- Do you strict to add salt (washing machine salt and not cooking salt!) at time. Its effects water hardness.
- Do you strict to add the rinse aid at time.
Comments:
Sep 18, 2007
- You should buy a dishwasher salt (don't put in cooking salt !!!!!)
The dishwasher salt is a particular grade of crystalline sodium chloride intended for use in dishwashers.
Was this helpful?
Yes
No
Solution #4
posted on Mar 11, 2009
Very Helpful)
Chuck-AZ
Rank: Apprentice
Rating: 100%, 2 votes
The dishwasher salt response is acceptable for Europeans, but U.S. dishwashers do not have a salt dispenser, nor is dishwasher salt sold in U.S. stores. U.S. consumers should descale their dishwasher using Dishwasher Magic, Lemi-Clean, Lime-A-Way, CLR, or vinegar until scale is removed from the machine, then add a rinse aid to the dispenser, which should prevent future problems. For very hard water, regular, periodic descaling treatments should be done. For the vinegar cleaning, place a full cup (8 oz) of vinegar in the top rack of the dishwasher. This way the vinegar is release throughout the wash cycles, performing a more thorough cleaning.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Apr 09, 2008
Somewhat Helpful)
amir ali
Rank: Apprentice
Rating: 75%, 1 votes
  1. Over the past 2 weeks, my cups have a sand like substance in them. I have hand washed every item before loading and even changed brand of dishwashing detergent. I then took out the screen in the bottom and cleaning it. It is still happening...help!
Was this helpful?
Yes
No
Solution #6
posted on Apr 17, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you have scaling problem , your water is hard and you need salt to avoid scale build ups, and gleams on the dishes. you have to determine first your hardness level in your locality, once you have your hardness level, set or program your machine to that level by pressing the command button, see the manual,there is an instruction how to preset your machine for water hardness level., the led light will blink according to the hardness level you choosed, for example it blinks 4 times it is preset to hardness level 4, if the hardness level on your place is at that level it should be your setting,after that turn off the main switch, your machine is ready.note:use only dishwashing salt not culinary salt.
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
what brand dishwasher should i buy?
Answer
What new dishwasher do you recommend. I have a family of 7 and the dishwasher is constantly in use.
Answer
I have a Frigidaire fdb1100rhm0 dishwasher that has a loud squealing noise during wash and rinse... (More)
Answer
just received a kenmore dishwasher it has a place for salt and soap .. I put the soap tablet in but... (More)
Answer
my dishwasher is stop working.no powerlight.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dishwashers:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
