Question about Microsoft Windows XP Home Edition
In sticky keys cannot fix by any way
Cann6t fix
  • 326 Answers
Access the control panel
Start > Control Panel > Accessibility Options
OR
My Computer > Control Panel > Accessibility Options
You will find the sticky keys option their.
If you are referring to physical sticky keys, and not the accessibility software option in windows:
Using a can of compressed air to remove debris from your keyboard should solve this issue.
Let us know
Good luck
Posted on Apr 14, 2009
Suddenly I can't type symbols that require the shift key. Capital letters work normally as do numbers.
Not sure if this is what your looking for but you might try to give this a try . It Could be your sticky keys and the worse thing: they can be activated by mistake. Sticky keys make it so you don't have to hold the shift, ctrl, alt and Win keys in order to activate their special functions. You can hit shift, let it go, and then hit a letter. You will get a capital letter.
How do you activate it? Usually by tapping on the shift button five times in a row. When you do that, a beep sounds, and the above dialog box appears. If you're not paying attention, you might just hit yes without realizing, it is the default answer after all, and you're stuck with sticky keys.
So how do you fix it? If you've managed to activate sticky keys by mistake, tapping five times on the shift button will turn them off. You won't see a notice about it, but you'll hear four beeps, and then a distinctive downwards beep. Sticky keys are now off!
Apr 05, 2018 | The Computers & Internet
The.spacebar.stopped..working.
If your space bar isn't responding when you press it, or if it responds sluggishly, it's possible that you have inadvertently enabled the "Sticky Keys" or "Filter Keys" accessibility option in Windows.
When these options are enabled, your keyboard response time will be dramatically slowed and may require more than one tap to register a keystroke.
Fortunately, it's easy to disable these functions and return your keyboard to normal working order.
Click "Start" and select "All Programs."
Click "Accessories" and select "Ease of Access."
Click "Ease of Access Center."
Click "Make Keyboard Easier to Use."
Click "Set Up Sticky Keys." Deselect the checkbox that says "Turn on Sticky Keys When Shift is Pressed Five Times." Make sure the box that says "Turn on Sticky Keys" is not checked. Click "OK" to save your changes.
Click "Set Up Filter Keys." Uncheck the box that says "Turn on Filter Keys."
Click on the checkbox next to "Turn On Filter Keys When Right Shift Is Pressed For 8 Seconds" to deselect it. Click "OK" to save your changes.
Click "OK" again to save all of the keyboard accessibility changes you have made.
Hope this helps
Oct 29, 2012 | Gateway LT2021u Netbook
How do I fix sticky keys on netbook?
Physically sticky keys because you spilled something on them or sticky keys keyboard shortcuts?
The first you don't really unless you want to dismantle the keyboard and clean the entire thing (do-able but it would take you a long time and you risk breaking the pieces under each key) I would just buy a new keyboard on ebay for $15-30 and have someone replace it.
Second, keyboard short cuts you can disable under Control Panel > Ease of Use > "Make the keyboard easier to use" and uncheck sticky keys.
Comment if you need more assistance and please rate the solution if you found it useful.
Thanks,
Justin
Nov 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Sticky keys how do i fix it?
Hi Dgr Welcome to fix ya !
The sticky keys are part of Windows Ease of Access Center Accessibility program.
1. The easiest way to enable/disable the sticky keys is to press the "Shift " key five times. This will turn on/turn off the program.
2. The second way is to press the Windows logo key + U at the same time. This will open the Ease of Access Center. Then select the link that reads" Make the keyboard easier to use."
3. Under the section that reads, "Make it easier to type" you have the option to enable the Sticky Keys or a link to Set Up Sticky Keys. Select whether you want to set up the Sticky Keys or just enable them if you have previously set them up. If setting them up for the first time, remember to click "Apply" after making your selections.
Hope this helps. If you need further assistance, just leave a comment at the end of this solution and I'll be glad to help. Thanks for using Fix Ya.
Jul 10, 2011 | Computers & Internet
Keep getting F1-8 keypad short code can this be fixed?
You have some junk making the key sticky. Before buying anything use a hot hot damp cloth to loosen up the sticky key.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2011 | Maytag Gemini 30" Self-Cleaning...
Shift key not working
You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
**Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
**If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
May 29, 2010 | HP Compaq nc6000 Notebook
Aspire 4720 PC Notebook: sticky keys, some liquid wet the keyboard...
Its hard to get them working again properly, i had to replace 4 sticky keys finally. I found this company who sell laptop keyboard keys at a very good rate, and even have tutorial's on how to fix the keys , that makes it really easy ...
www.laptopkey.com
May 17, 2010 | Acer Aspire 4720 Notebook
My letter 'e' is sticky and I have to press extra hard - do the individual keys come out of a laptop Acer 5720 please
Hello, If your laptop keys are sticky and its causing problem typing, you can replace just the one key which is sticky, visit this site
www.laptopkey.com
I got two of my laptop keys fixed by this company and im satisfied by their service, they send all the underneath fixings with the key , so its easy to fix , hope this helps you :)
Jan 05, 2010 | Acer NSK8458AN Keyboard
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
Sticky key
i have the same problem with letter m before and now comma has the problem!
Jul 26, 2008 | Compaq Keyboard
Microsoft Windows XP Home Edition Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
