Problem for Standard Televisions
Generic problem for all Standard Televisions
Sanyo AVM-3289G TV will not turn on
TV started to require multiple button bushes (on the front panel) to turn on. It worked fine via the remote. Sudenly it will not turn on at all. There is a high pitch whine coming from what I beleive is the power supply area.
I took my multimeter and measured around the CPU and noted that no voltage is present on the VCC and VSS on the chip. I can not seem to find a service manual to show me a schematic, so it makes it difficult to isolate the problem.
The front panel switches and the IR receiver connect directly to the CPU I/O so I would presume there must be voltage always present at the VSS/VCC pins for the power to work.
Any ideas for me on what I can check, or further information I can use to fix this TV?
Comments:
Sep 13, 2007
- What am I looking for on the Cap? What voltage should it be? The 3 pin transistor, what should its pins be/look like?
I would also suspect the HOT or Flyback, but why would the power button act funky and then stop and now no power on the CPU. I would guess the HOT/Flyback failed.Sep 13, 2007
- It looks like the HOT (marking D1880) is shorted from C>B>E all read 0 ohms.
There is no voltage present but I would expect that since I can not turn the TV on because of no power to the CPU, right? Do you know if the flyback is across the transistor that would make it appear as a short?Sep 14, 2007
- I removed the HOT and now the 5V comes back. Appears the short caused the power supply to be pulled down. Once I removed this part, I am able to hit the power button and the unit turns on, however, it turns off after 3 seconds. This is due to a voltage monitoring circuit that automatically shuts the unit down when all voltages are not present. I have ordered parts (HOT and Flyback) I will try to replace just the HOT and see if that resolves the problem, if not, I will replace the Flyback as well. I even ordered a spare HOT incase the first pass fails and takes the HOT with it again.Sep 20, 2007
- You were 100% correct. The HOT was certainly bad. The Flyback was fine. I installed the new HOT and put the set back together and it works like new.
Same Problem
Mar 13, 2008
-   Sanyo AVM-3289G. Sounds as if it is powering on when power is switched on. No picture or sound and it powers off within a second or two. Fuse is not blown. I appreciate any help. Thank you. Chirs-
Terd Pnugit Jan 03, 2008
-   i was watching a movie and the tv turned off by itself.i tried to turn it back on but it turned itself off again withing a second or two and the light on the front of the tv start to red green red green etc.. I have the sanyo 32" , i hope u can help me
Thank you-
adelkhattab Nov 20, 2007
-   we were watching a movie and the tv turned off by itself.i tried to turn it back on but it turned itself off again withing a second or two. I have the sanyo avm-3289g-
coolpop
Best Solution
posted on Sep 13, 2007
Rank: Wiz
Expert
Rating: 84%, 1295 votes
Probably flyback in this set, but you can check Horizontal output, a 3 pin Transistor standing up on a heatsink. Also Large cap in powersupply.
Popular Solutions for Standard Televisions
Sony FD Trinitron WEGA KV-30XBR910 30" TV
1 Solution
Sony FD Trinitron WEGA KV-32FS120 32" TV
1 Solution
Questions and Unsolved Problems for Standard Televisions
how to remove child lock on sony tv without use remote
I have a sanyo MTS and need the manufacturer code to program a sony remote for it
my tv is attached to a cable inpt but no cable box i am able to watch all cable channels by...
(More)
my tv is attached to a cable inpt but no cable box i am able to watch all cable channels by switching tv chanels,is the inpt digital or analog
how to input a dvd signal
I need the program code and directions to setup my sony RM-SS300 av system remote for a Panasonic...
(More)
I need the program code and directions to setup my sony RM-SS300 av system remote for a Panasonic PV-V4622 VHS VCR and a Sharp 25R-M100 25" TV. I got them as a temporary fix for my stolen tv. Thanks for the help.
