Question about Onkyo DR-C500 Multi-disc DVD Player
Seems stuck in standby
My wharfedale dvdr24hd160f is stuck in what seems to be standby. it has a blue light on but no other display. i have no remote for it and no clue as of what to do is there a quick fix for this?
  • Anonymous May 20, 2009
    As above.
Wharfedale dvdr24hd169f stays in standby no displays wont accept commands
The problem is in the power supply board, often caused by a defective capacitor that becomes open, cap value is usually around 1000uf and sometimes shows a bulge at top leaking contents, if you are handy with a soldering iron replace part with identical value and voltage rating and observe the polarity.
Jun 09, 2012 | Wharfedale Televison & Video
User manual wharfedale dvdr24hd160f
http://www.download-genius.com/download-k:wharfedale+dvdr24hd160+manual.html?aff.id=6418
Jan 02, 2012 | Televison & Video
Stuck with blue light on, no display and not responding to remote control Any Ideas?
Possible failure of the main control panel, possible the processor is malfunctioning or faulty.
remove and fix back all connections and connectors.
if there is no action or response then the processor/associated circuit/mother board can be defective
Apr 11, 2011 | Wharfedale LP160DTRHDMI
Im looking for wharfedale dvdr24hd160f recorder manual as i never got one iwth player. thx bri
Could be a problem with the SCART vs HDMI output. Try CLEAR-CLEAR-4 to reset - worked for me!!
Nov 08, 2009 | Televison & Video
Wharfedale DVDR24HD160F No picture on TV and SET UP on display
check the leads our pushed in firmly, then turn the dvd player off leave for 5 - 10 mins turn back on and hopefully setup instructions will be displayed on your tv follow them thro and that should fix your problem :D
Mar 10, 2009 | Televison & Video
Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Oct 24, 2008 | Olevia LT37HVS 37 in. LCD HDTV
I have a wharfedale DVDR24HD160F. I ejected a DVD out of the machine, when the drawer closed it then said no disc. This was displayed for some time and by the time I realised the machine was frozen. I...
hi there
its an outside chance but if you hold down the power button and the play button together when you plug the player in it usually resets the software. if it doesn't work, what the hell it was a freeby !
good luck
beergut707
Oct 07, 2008 | Wharfedale Televison & Video
Wharfdale DVDR24HD160F
Hi Barb22,
Sounds faulty to me, I'd take it back to the store and get a replacement. However, I guess you want that DVD out first? I'm not sure this will work because the units logic board is mostly likely faulty and will prevent the DVD transport from opening. Unplug the unit and press the eject button, keeping it pressed plug the unit back in. If the unit does not come on then press the power button too. If the unit starts to open release the button immediately. It's unlikely to eject, but you might get lucky.
Sorry I can't be of much further help.
Regards,
Spare head 2
Please don't forget to rate this response.
Jan 13, 2008 | Wharfedale DVD-M3 DVD Player
Onkyo DR-C500 Multi-disc DVD Player Logo
189 people viewed this question
Top Onkyo Televison & Video Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
