Question about Samsung TXN2745FP 27" TV
Samsung TXN2745FP Our TV just stopped working altogther. It will not turn on. We have tried other outlets, but nothing happens when we push the power button or use the remote to try and turn it on. We have had no problems befor this so we are baffled why it will not work all of a sudden.
  • Anonymous Jan 26, 2009
    The TV shut down. there is no longer a lit red LED which would indicate a power supply problem. I switched cord to a known good supply. No change. Is there a reset button or fuse?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
1 your power must have failed get it checked. 2 there might be problen in horizontal section.
Posted on Sep 13, 2007
SOURCE:
Sylvania tv stopped working
Something may have happened in the DVD unit to take out the main fuse in the power board, start by checking that
Dec 04, 2017 | Sylvania Televison & Video
Plasma TV-power light does not come on
have you tried a completely different wall socket altogther/
Mar 03, 2008 | Samsung HP-S5053 Television
The TV will not turn on anymore. I used to have a difficult time turning it off by pressing the on/off button, and then it stopped turning on altogther. Trust me, I have checked the plugs, tried different...
it sounds like the power switch has gone out it you might be able to remove the actual button itself and try pushing the switch with a rubber handled screwdriver
Mar 03, 2011 | RCA D52W136D 52 in. TV/DVD Combo
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to [email protected]
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
TV won't turn on
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 25, 2008 | Mitsubishi WS-65511 65" Rear Projection...
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Samsung TXN2745FP 27" TV Logo
122 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
