Question about Brother GX-6750 Typewriter
Correction function not working
Hi, i typed a wrong letter and press the correction button. the typewriter went back to correct the letter but the letter is still clearly there. when i looked at the correction tape, the incorrect letter was etched onto the correction tape. I looked at the manual and installed it the way it asked me to but i still get the same results. Please advise. Thank you.
I've found that if I don't use the machine for a few weeks the correction tape that is exposed to the air becomes ineffective. I make a bunch of corrections in a row until fresh tape comes off the roll and the correcting function starts to work again.
Posted on Oct 09, 2007
  • 481 Answers
Make sure the ribbon is a correctable (yellow or orange core) not a multi strick (blue core)
Posted on Sep 17, 2007
SOURCE:
Is there an auto correction feature
The key to the right of the spacebar with the "X" printed on it is the correction button. You just place the carrier on the character to the right of the wrong one and hit the corr. button. The carrier should automatically back up and and remove the incorrect character and if you hold the key down it will continue to back up and remove characters. then you just type in the right one(s). Of course you have to have good "correctable" ribbon and correction tape cartridges installed. If the tapes are old you may have to advance them by typing and correcting or by manually advancing them before they will work. If the correction doesn't remove all the ink from the paper you may have a bad ribbon and/or correction tape.
Sep 17, 2015 | IBM Wheelwriter 3500 By Lexmark Electric...
What buttons do I push to erase on my sx4000 brother typewriter
Providing you have the proper supplies and they are correctly installed you just type a wrong letter, press he correction (KEY WITH AN ARROW AND AN "X" ON IT).
DickyO
Sep 29, 2011 | Brother SX-4000 Typewriter
How to make a correction
Type a wrong letter, press correction key (X WITH AN ARROW POINTING NTO THE LEFT) should remove Mistake. If this dosen't work you may have very old supplies or a non correctable ribbon.
DickyO
Dec 14, 2010 | Olympia Standard 300 Typewriter
Correction bar not working. When I type in a word and hit correct, instead of lifting the lettter off the paper it types the letter I typed in bold. Is there a button I can push to correct this from...
The correction tape may be installed wrong, or it may be a tacky L/o that will stick nand not raise up..
You can find a manual at BROTHER.COM, click on support.
DickyO
Sep 02, 2010 | Brother EM-530 Typewriter
We can't find the instruction manual to our Nakajima AE-710. How do you make the correction tape work?
Type a wrong letter, press the key with the X and a L. arrow on it correction complete.
DickyO
Aug 05, 2010 | Nakajima AE-710 Typewriter
We have a IBM Wheelwriter 5. Need to use
Correction is pretty simple type a letter, press the correction key and it should lift the wrong letter off.
DickyO
Sep 30, 2009 | IBM Wheelwriter 30 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
Warning sound, didn't move
Check to be sure the correction tape isn't tangled in the print wheel. If it is or was check the wheel to be sure it isn't damaged,
Then try it without the correction tape.
DickyO
Apr 04, 2009 | Brother SX-4000 Typewriter
Typewritter won't correct!
After you press the corr. key you must retype the wrong letter then type the correct letter.
DickyO
May 15, 2008 | Office Equipment & Supplies
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Brother GX-6750 Typewriter Logo
182 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
