Question about Canon PIXMA MP150 All-In-One InkJet Printer
The paper doesn't feed into the printer. help!!!
When i try to print, the paper doesn't enter into the printer. It sort of lops to a side and the printer prints on no paper.
how do i fix it?
  • banful_a Apr 15, 2009
    thanks very much!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 153 Answers
The problem is you have something stuck in your paper path thats why the paper is being dragged to one side, its very common for a canon machine i have removed so many things from the paper path,
Canon Printer tech
Posted on Apr 14, 2009
First open the printer , its due to paper fibre on the sensor or some part of paper lying in printer Clean the printer and the Sensor , and then try again
Anirban
+919434878250
Errors with my Printer/scaner
Jessica:
This could be one of a few things... First, Windows 8 is a completely different animal from Windows XP! Try reloading your printer driver in Windows 8. If this doesn\'t work, you need to clean the paper pickup rollers at the front of the printer (where the paper first feeds into the machine. I use a Q-tip moistened (not sopping wet) with rubbing alcohol... gently scrub the whole pickup roller and then the feed roller next to it. Check carefully (with a flashlight) for any shards of paper that might be blocking the paper path. There is also a sensor flag (small finger of plastic) sticking up that the paper must hit to let the printer know that the paper is feeding through. If you do not see the sensor flag, it is either jammed or has been broken off when a piece of paper was pulled backward out of the paper feed area. First reload the printer driver, and try to print. If it doesn\'t print, check and clean the rollers and look for the sensor flag.
May 31, 2014 | HP 1050 Plain Paper Inkjet Fax
Black dots are printing on the left hand side of the page when I print from my hp laserjet 1015. Any ideas how to fix this?
Run a "half test". Put paper in the manual feed tray. Print anything. Watch the paper, when it feeds about 1/2 way into the printer, open the cover. Pull out the toner and look down at the paper. If it has the dots, replace the toner. If it doesn't have dots, the fuser is probably bad.
Aug 31, 2011 | HP LaserJet 1018 Printer
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Paper feed wont take paper to print gets crinkled and wont print
This is sort of scenario could be caused by dust inside the printer. Dust prevents the rollers from having a firm grip on the paper while picking paper. When one roller has a firm grip and rolls the paper well while the other doesn’t, crumples result. So I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front; if you have a blower please use it as well). This, if properly done should do it. Brush especially the rollers etc.
Dec 21, 2009 | Canon Pixma MP500 All-In-One InkJet...
Hp l7590b no paper load
hi friend,
Step 1Turn on your printer. Make sure it is plugged into an electrical outlet and installed properly.
  • Step 2Wait for your printer to stop. Do not load paper while it is printing or running any kind of maintenance operation.
  • Step 3Prepare your paper. Make sure your paper is right side up (glossy, whiter or label side should be facing up). Make sure all the pages are lined up together, like a deck of cards.
  • Step 4Locate your paper tray. Some printers have a manual tray and an automatic feed tray. Refer to your printer’s documentation to find the automatic feed paper tray.
  • Step 5Place your paper in the tray. For 8.5 by 11 inch (standard) paper make sure the 8.5 inch side will be fed into the printer.
  • Step 6Set the paper guide. This is the movable piece on the side of your paper tray. One side should move and the other should not. Move your paper so it touches the side that does not move, and slide the paper guide so it touches the other side. Some paper guides have markings so you can set it to the exact measurements if you know the size of your paper.
  • Step 7Set the paper thickness lever. Refer to your manual to determine which setting this lever should be at. Generally, standard paper does not need a different setting and special media like glossy photo paper or envelopes should use a thicker setting. You can usually access this lever the same way you access your ink cartridges.
  • Step 8Let your printer know what it is printing. If you are using a special media, then set the options before you print. Click “Properties” on the print dialog before you print something. From there, change your media type to whatever kind of paper you loaded.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • Fan your paper back and forth before lining it up to load into your printer. This prevents static build up which is the leading cause of paper jams.
    • If your printer doesn’t feed the paper correctly at first, try making slight adjustments as it tries to feed to find the right spot.
    • Refer to your manual for in-depth paper loading instructions.
    • Many printers have a resume/cancel button. This is to be used when you need to load paper mid-print job.
    • Do not overload your printer.
    • Avoid non-standard media types such as loose leaf paper with holes or folded or wrinkled paper or anything with affixed stamps or stickers. These can jam your printer.
    hope this helps u
    please rate me...........................
    thak u for using fixya
    regards
    sivaranjini
    Dec 01, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
    I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
    I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
    Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
    Hope this helps
    nickerjo,
    leaningpalmstudio.com
    Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
    How do you load an envelope in the printer?
    Hi, Please follow these steps to load :-
    1.Turn on your printer. Make sure it is in ready mode (green status light on) and it is not printing or running any other operations.
    1. 2.Determine whether your printer uses a top-feed or bottom-feed. Blank paper stands upright in a top-feeding printer and lays in a tray on a bottom-feeding printer.
      3.Load your envelope in portrait mode for envelopes that are 8.5 inches wide (standard paper size). Fold the flap down and place the envelope with the side to be printed on facing you. Load the envelope so that the side with the flap enters the printer first.
      4.Load your envelope in landscape mode for longer envelopes that cannot fit in lengthwise. Close the flap. Load the envelope so that the left side enters the printer first (the flap will be on your left).
      5.Set the paper guides. This guide is the sliding piece on your feed tray (it will usually be on the left). Slide it over so that the paper is held straight when it enters the printer.
      6.Set up your printing preferences. Go to "File > Page Setup" or access your printer’s properties page. Under orientation, select portrait or landscape mode depending on how you loaded your envelopes. If your printer has this option, select “Left” for bottom-feeding printers and "Right” for top-feeding printers
      7.Take a look at the "Print Preview" (usually found under "File" menu) and make sure everything looks good. Then print.
    2. Thanks!
    Oct 02, 2009 | Office Equipment & Supplies
    My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
    1. Try cleaning the paper feed rollers
    Instructions how to clean the paper feed rollers.
    If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
    If paper does not feed correctly, perform the following to clean the paper feed rollers:
    1. Open the Printers folder.
      - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
      - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
      - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
      - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
    2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
    3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
      Remove all sheets of paper from the rear tray, then click 'OK'.
    4. Confirm the message, and click 'OK'.
      Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
    5. Confirm the message, and click 'OK'.
      After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
    6. Confirm the message, and click 'OK'.
      Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
      Click 'OK'.
    Roller Cleaning is completed.
    Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
    Epson R220 paper feed lop sided and jammed
    try putting a thick piece of card thro the paper path. this tip was given to me by an approved epson repairer. evidently paper pieces and other bits get stuck in the paper path. hope this helps , good luck
    Nov 22, 2007 | Epson Stylus Photo R220 InkJet Printer
    Paper isnt loading correctly
    My printer does that too, after many copies have been printed out. There is this mechanism that pushes the paper forward and another to slide one paper in... well it won't get in. I tried to add "grease" at the right side, "facing the printer", of that mechanism that made contact to the rollers which slides a paper in..  well my printer now works fine
    Mar 19, 2007 | Canon Pixma MP450 All-In-One InkJet...
    Canon PIXMA MP150 All-In-One InkJet Printer Logo
    old marine
    old marine
