Question about Akai LCT2716 27 in. LCD Television
Akai LCT2716 Flat Panel TV
Light blinking red (bottom right); TV will not power on; some popping sounds in speakers
  • 3 more comments
  • Anonymous Jan 20, 2008
    we have 27 inch lcd #LCT2785TA-turned tv off 2 days ago-was fine-cant turn back on-red light staying on only help?
  • gdille Jan 21, 2008
    set would not go off of standby(red light) turned off power and now will not power up (no red or green light)
  • maz15 Feb 19, 2008
    TV just went off, no picture or sound just a red blinking light.
  • brewcrew035 Mar 02, 2008
    Red light at bottom right corner blinking and some erratic popping sounds out of speakers!
  • joannjalloyd Apr 21, 2008
    Turned tv off two nights ago. Tried to turn back on last night. The only thing I get is a blinking red light. Purchased a new power cord. Same problem. Purchased the tv 2 years ago a Sam's Club. Can it be fixed or should I just toss it out?
Mine started doing the same thing.
I turn power off (pull Plug) for a few seconds then try again.
Works OK but must perform unplug procedure each time.
Posted on Mar 01, 2008
I HAVE A RED BLINKING LIGHT ON MY TV ANY IDEA'S HOW TO FIX?
Posted on Jan 14, 2008
Standby red light just continuesly blinks, no picture -
TV TURNS ON 1-2 SEC SCREEN SHOWS COMPONENTNT1 AND TURNS OFF WITH A POP SOUND FRO9M SPKRS
May 17, 2009 | Akai LCT2701TD Television
Power on no picture
Power supply PC board must be rebuilt = replace all bad capacitors.............T.
Aug 19, 2008 | Akai LCT2716 27 in. LCD Television
Akai LCT2715 Blinking Power Light
Hire a tech directly to replace all the bad capacitors on the power supply PC board.....................T.
Aug 03, 2008 | Akai LCT2716 27 in. LCD Television
Akai tv wont come back on
Nothing......bad capacitors in power supply need replacing.....T.
Jul 16, 2008 | Akai LCT2716 27 in. LCD Television
Akai LCT2701TD
I HAD THIS TV AND TOOK IT IN TO BE FIXED AND THEY NO LONGER MAKE THE PART SO I CHUCKED IT. THANK GOD I BPOUGHT A WARRENTY ON THIS TV I ONLY HAD IT FOR A YEAR! NOT A GOOD BRAND
Jul 09, 2008 | Akai LCT2716 27 in. LCD Television
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
Mar 12, 2008 | Akai LCT2715 27 in. LCD Television
Akai 3216 TV
I own a Akai TV but when we bought it, it was working fine. Then we moved it to a different position and plugged it in.. Now the red light keeps blinking and then it shuts off.. then about maybe a minute later it turned on by itself. can anyone tellme what the problem is???
Sep 18, 2007 | Akai LCT2716 27 in. LCD Television
Akai lct2716
you have fault oscillation you hve defective parts inside!
Sep 14, 2007 | Akai LCT2716 27 in. LCD Television
Akai tv 27"
This model is notorious for power supply problems (mainly bad filter capacitors). They are large electrolytic capacitors located at the top of the switch mode power supply (SMPS) board. Most of the time they are easily spotted (the tops are pushed out in a dome shape rather than the flat top they are supposed to have) but it could be something that is not so easily detected. At any rate, the power supply is probably to blame, and unless you have knowledge in electronics repair, it will have to be serviced by a repair tech...
Hope this helps you out....
Jul 01, 2007 | Akai LCT2716 27 in. LCD Television
Akai LCT2716 27 in. LCD Television Logo
362 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
