Question about Averatec (24-20705-00) Heatsink With Fan
Averatec lap top av3500t
Im have av3500t laptop get to hot battom no sreen display no power som one sugest heat sink how ca be sure before i buy the part
  • 42 Answers
Hi As you have stated that you have no power this means that the CPU is overheating and is unable to complete the function of opening the operating system if you can feel the large fan that circulates air throughout the laptop you can generally say that the power is reaching the mother board but the CPU is getting to hot to function therefore i would sagest that you see about getting a heat seek fan for your laptop if you take it to a reputable computer store they may replace it for you and double check it for you Hope this solves your problem Paddy
Posted on Sep 13, 2007
My lap top keeps shutting off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 23, 2012 | Acer Aspire 7720 Notebook
My processor is getting hot. What will be the solution.
Turn it off ... it will not get hot.
Typically, normal temperature is over 100 degrees. There have been reports of fires starting as the result of a overheated PC. I am not making the claim, I have not had this experience.
Heat is the enemy of delicate computer parts. They call them Lap Tops but you should never use one on your lap. Always place your lap top on a hard surface to insure the vents are not blocked and the internal fan can try to do its job. If you are concerned about the heat, you can get a 'cool pad' to use under your lap top. A cool pad has a fan which blows onto your lap top to keep it cool. The cool pad gets its power from a USB in your laptop. This cool pad should not be used for long periods of time on battery power for obvious reasons.
Thanks for your question at FixYa.com
Jan 30, 2011 | Computers & Internet
My averatec lap top os stuck in sleep mode
Hi. I suggest you try pressing the power button to wake it up or you could also try power draining it and turting it on. To powerdrain your computer you must remove first the battery and unplug the ac adapter then press and hold the power button for 20 seconds, after that you must place back the battery and plugin the ac adapter then turn on your computer. Hope This Helps
Jun 02, 2010 | Toshiba Satellite M100 Notebook
Power
If the fan is spinning quite fast then the overheating problem is most likely dust clogging the fan and heat-sink assembly. Blasting air into the fan and heat-sink can only make it worst as you are forcing the dust further into the heat-sink fins.
Remove the panels covering the vent and fan/heat-sink, loosen the dust and vacuum to remove this dust off the fan and heat-sink. Check the fan to see if it spins freely, if not replace the fan.
After re-assembling and boot up, if you still have heating problems, addition cooling can be employed by purchasing a laptop fan assisted cooling pad. Place the laptop on top of this pad and the fans on the pad will direct additional cooling air to the laptop's vents.
Mar 08, 2010 | Gateway ML6732 Notebook
Im looking for averatec main phone number so i can report my pc stolen and get info for my reports
http://www.averatec.com/
Street address:80 Icon
Foothill Ranch, CA 92610
Phone:714-429-8999
Email:sales@averatec.com
Fax:714.429.9960
Feb 19, 2010 | Averatec 3200 Notebook
My medion laptop keeps overheating
change your laptop heat sink fan
Nov 11, 2009 | Computers & Internet
SHUTS DOWN RANDABLY
What we need to do if determine what temperatures your computer is running at, download and run this software.
http://www.cpuid.com/hwmonitor.php
Please post what the temperatures read after you have had the computer running for a little while. Most likely this issue is a heating issue. Thank you.
Apr 27, 2009 | Averatec 6100 Notebook
When i turn on my lap top it boots up to my home page then it sta
in control panel
then display
in desktop set to none click apply and restart
let me know if that fixed ya
if not we can do another solution
Feb 14, 2009 | Averatec 3200 Notebook
My lap top is extra ordinary heated after some time.what is problem?
You didn't mention if you had a laptop or a desktop. But on a laptop there is a small fan on the power supply that cools the CPU and all inside. The laptop must always be used on a flat surface like a table to ensure the air is circulating properly. Putting it on your lap or on your bed will cause it to heat more than usual. Yes they do get hot, the tempature is monitored by your BIOS and will automatically shut down if it gets too hot, this is to save the CPU from being damaged. As long as things are working properly then you are ok.
Dec 24, 2008 | Intel Socket 775 Heat Sink and Fan up to...
Besides the fan underneath the pc. it runs hot
Sad engineering-
See if one of the available aftermarket 'fixes' seems suitable for your units:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-37,GGLG:en&q=laptop+cooling+base
This is unfortunately, not an uncommon problem. Modern processors dissipate way too much heat in a small area, one of the prices of ever more dense packing of circuits in the quest for more speed and processing power.
Jun 10, 2008 | Averatec 3200 Notebook
Computers & Internet Logo
70 people viewed this question
Top Averatec Computers & Internet Experts
Steve Allison
Steve Allison
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
