Question about MSI K8MM-V Motherboard
My mother board problem is first time 10 minut full working after 5minut systenmhang system restart not powering on
I want INTEL D 945 GCR Mother Board Driver CD Download mail me proper download link address. rajreet.omm@gmail.com
Posted on Apr 17, 2009
P 4M800PRO-M V1.0A ECS mother board does not beep ,it gives click sound . but some time it start and run good condition .and next restart ,mother broad doesn't start
Sounds like that board is on its way out. Had a good run too!
I'd seek out a complete system upgrade.
Small things you could try is reseating the RAM and testing it with a new power supply.
Hope this helps!
Sep 16, 2014 | Computers & Internet
Model IWL12 is showing "Power Cut restart in 10 secs" what is wrong.
Your motor controller board has faulty power supply,
Board needs replacing.
Dec 17, 2012 | Fisher and Paykel IWL12 Top Load Washer
My Computer working properly but some time suddenly monitor turn off (not standby) that time restart / power off button not working.only way to restart/off computer unplug power cable. after restart same...
Hi friends ,
It is *********** board problem,Because the over heating. Go to bios and set the FAN control disable.
If same problem
Change the CPU FAN .
If the problem same .
You will think, the censer of the mother board, has damaged and that's why,censer of the mother board think that CPU is cross the temperature limit. It is the main reason.You need another mother board,sorry to say you.
Hope it will help you.
Dec 20, 2010 | Intel D915GAV Motherboard
Donot startup
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
Hope this helps.
Good Luck.
Live, Love, Laugh.
May 15, 2008 | Acer TravelMate 2300 Notebook
Acre 5520 laptop
Assuming already installed vista.
Just try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer,scanner & monitor and power supply from the CPU.
Is it giving any error messages.
Try booting in to safe mode.
If it does then the issue is with something.
Do you have two video adapters.
Try boot from the dvd & run the recovery for vista.
or the system restore from the dvd.
At last run repair reinstallation using the vista dvd.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
System restarts automatically
1st) I would suggest disconnect EVERYTHING from the motherboard. Keep keyboard, mouse and of cause the monitor.turn on....wait your 10-15 minutes, play with the keyboard, flutzz with the mouse..
Nothing happens,TURN OFF cpu, add ONE other device, continue doing the same thing until something happens after a device is installed, that could be your problem. 2nd) your turning on and off the power supply could cause it to crash, then THAT is your problem.too Low or too high power supply voltages causes your cpu to reset in order to protect itself {By forcing the power supply to "crase & burn" u forced the issue.
Apr 23, 2008 | ASUS P5PE-VM Motherboard
Help
Try reseating the drive(diconnect & reconnct the drive).
Or
Completely shutdown?
That is, shutdown and remove all power from all devices and power bricks for a 10 count and try again?
How about plugging that into another USB port? Some discover some ports will not work, but report "OK".
Or
You can run the diags on the drive, you can get from here
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=fa-desktop-sw&vgnextoid=e7acb5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Or
you can try this
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ext-ts-vista&vgnextoid=694d8b0e50e73110VgnVCM100000f5ee0a0aRCRD
Check this
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD
Good Luck.
Live, Love, Laugh.
Apr 22, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Restart
dear chama119
scan your pc in safemode by updating your antiviruse(plz disable system restor)
Apr 10, 2008 | Intel D101GGC Motherboard
Hard Drive doesn't show up
And press & hold the power button for 2 min, it will release the flea power from the mother board.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Good Luck.
Live, Love, Laugh.
Mar 30, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
TO noggin
remove all pwoer connector from motherboard and short green and black wire in supply shocket.If supply is run then it is the problem of motherboard.
Feb 28, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
MSI K8MM-V Motherboard Logo
63 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
