No power - no PC - bad news!
I SWITCHED OFF MY GT5676 DESKTOP PC SERIAL NUMBER XBG8411009102. I PRESSED THE APPROPRIAR=TE BUTTON, BU THE POWER IS NOT REACHING THE PC. I UNPLUGGED THE POWER CORD FROM THE POWER SOURCE AND FROM THE PC. I THEN RE-PLUGGED BOTH ENDS. STILL NO POWER. I CHANGED THE POWER CORD AND RE-TRIED ALL OF THE ABOVE - STILL NO POWER. IS THERE ANOTHER SWITCH FOR THE POWER (OTHER THAN THE BUTTON WHICH SHOWS BLUE? NEED HELP BEST REGARDS IAN MIKBEN@SHAW.CA 425-424 SIMCOE STREET VICTORIA BC CANADA 250-384-5808
    Problem Solver:
  • 14 Answers
Check the red voltage selector switch on the power suppy next to the power cord. Make sure it is set to the right voltage. You may want to slide it back and forth a couple of times. Sometimes these switches can be dirty or not seated properly.
Posted on Apr 14, 2009
FUJITSU SIEMENS SERIAL NUMBER YKJW 033826 GIVES ME A PROBLEM WITH POWER SUPPLY IT BEHAVES ON AND OFF DOES NOT ENGAGE FOR ME TO GO ON WHAT IS THE PROBLEM?
The lithium battery might have failed.
A 0-Watt device consumes no current when it is switched off and in the quiescent state. Your 0-Watt device is equipped with an emergency on button (primary resume button) which can be
used if it can no longer be started, for instance because the lithium battery is discharged.
After the emergency on button (1) has been pressed for a short time, the device can be switched on again using the ON/OFF switch at the front of the device.
25484026-fzucfdts43yrrd4a0jvcakxw-3-0.jpg See the manual
File description
Feb 26, 2015 | Fujitsu Computers & Internet
Gateway desktop gt5676 . Doesnt turn off
If one desktop is not turned off while you press the on button in front of the cabinet or shutdown button in the screen means one of the driver in your desktop is not working properly. please check all the drivers or reinstall / update them
Jul 22, 2012 | Computers & Internet
Power supply replacement
This power supply should work out fine for you if you haven't added a graphics card. It's very popular and pretty inexpensive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153023
Jun 03, 2012 | Gateway GT5676 Desktop PC
I can't get a signal from my desktop to my hdtv when I use the hdmi port. The desktop is a gateway GT5676
First, make sure the computer port is working in the computer by going to the device management ICON in control panel.
Once you check that, make sure you have set up your preferences in the TV to allow "INPUT" from the HDMI port. If you have more than one HDMI ports make sure you have the correct number listed. This is a common error. It would be the same if you are running a DVR with an HDMI cable, you need to set up the TV. Normally you hit the "INPUT" button on the remote control and a list pops up. Scroll over with the arrows to the correct HDMI port. You will likely need to do this again to get back to the cable input once you are finished with the computer connection.
Feb 10, 2011 | Gateway GT5676 Desktop PC
My eee pc 1005hab was dropped on the floor breaking the charger while still in the port, i took the charger out, netbook still on and used it till the battery died. that was two weeks ago. i now have a new...
I am afraid that I have bad news. You have more than likely broken the connector in your computer. Unless you know someone that can open the case and try to repair it you will need to send it in for repair.
Jan 05, 2011 | ASUS Eee PC 1000HE Netbook
My GT5676 goes black in the middle of things. I
have you tried replacing the monitor or the LCD? if not please do so then try.
May 15, 2010 | Gateway GT5676 Desktop PC
Is it powering off, or is the display just going black? Check to see if the keyboard is still active - can you see the Caps Lock light go on/off as you toggle the key?
Mar 28, 2010 | Gateway GT5676 Desktop PC
Installed new memory on gt5676, lost video output, have constant tone?
pput old memory back in if it works then you have a bad memory chip or the wrong kind or not matched up.
Nov 26, 2009 | Gateway GT5676 Desktop PC
My acer laptop wont start up!
sure lets do one thing disconnect the power cable and also remove the battery and than hold down the power button for 12 seconds and than put the battery back in and also connect the power cable and than start the system that should work
Feb 14, 2009 | Acer Aspire™ T180 PC Desktop
Cant shut down
keep start button pressed 30 seconds, the pc should turn off. If not brutally unplug the power cable. Do a scan disk on restart.
Feb 16, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
