Question about Sony Cyber-shot DSC-N2 Digital Camera
In camera or video mode it says turn the power off and on again
My camera Sony 10.1 megapixels when i open at video or camera mode it says turn the power off and on again plz solve this problem immediately
    Novelist:
  • 107 Answers
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
If the lense does not retract, but goes up and down when you turn it on or off, Clean the sides of the lense and while turning the camera off push the lense in NOT too hard for a few times. If it retrected 100% or most of the way inn, push the in a little harder untill it is 100% retracted in. Now your camera should be back to normal. 2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damaged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Posted on Jun 11, 2009
What is E:62:10 flashing code?
hi,
this error code indicates that some thing out of order related with the lens of the cam, if the camera section is jammed or dust entered in may be the cause, open the lens unit clean it with air blower ball, then fix.
Dec 19, 2015 | Sony Dsc-wx70 16.2 Megapixel Digital...
My sony cybershot wont turn on but has not been dropped, what may be the cause of this?
You seems to have a bigger issue than anyone can offer advice on this website. Consider taking your camera to a service centre for professional diagnosis and if possible a fix on your camera.
Sep 06, 2014 | Sony Cyber-shot DSC-WX60 16.2 Megapixel...
Turn camera off and on again
Can you come into the menus? Just to check you did not change anything? Sometimes the monitor or display stays black in record mode, because the camera was put in power save mode. In the manual you can find hoe to switch it on again. Has to do, with what you want to see during record mode. Just the image, image with info, sometimes with a grid and then display off.
Nov 26, 2013 | FUJIFILM FinePix JX680 16.0-Megapixel...
Len is not opening
The following video lists troubleshooting steps for a jammed camera lens:
Dec 13, 2012 | Sony Cybershot DSC-W55 7.2 Megapixels...
When turning camera on, it says turn the power off and on again
1. Could be a weak battery. 2. Press the delete, LCD power, and menu buttons while turning it on.
Feb 09, 2010 | Sony Cyber-shot 10.1-Megapixel Digital...
My sony cybershot 12.1 megapixel camera turns off and immediately turns off?
Hi, This problem is related to the lens block assembly, when turns the power the zoom motor stuck and set goes in power off mode. To rectify the problem you have to replace the lens block assy. you didn't mention model No. here so that i am not been able to tell you the exact part number of the camera. Thanks for using fixya.
Jun 14, 2009 | Sony Cameras
Can't get the full LCD to remain available-defaults to frame
Is it just the display that behaves this way? Please check the Image Quality option in the shooting or settings menu. Select the Largest option available (normally you get options such as Large and Fine). This will make the camera shoot in full resolution. After taking the picture, access the menu again and check whether the camera has automatically changed the Image Quality to a lower resolution.
Jan 31, 2009 | Kodak EasyShare One Digital Camera
Sony cybershot 4.1 megapixels mpegmovie vx dsc-s90
Your camera has problem in Lens mechanism. If Lens doesn't open properly, camera will not show picture at all. There would be Loading Motor section demaged in Lens mechanism and it needs to be replaced to work camera OK.
Now come to blue screen in playback mode, This model doesn't have internal memory, so you need memory stick/ card to see previously taken pictures.
Jun 21, 2008 | Cameras
Sony Cyber-shot DSC-N1 8.1 Megapixel
http://www.dcresource.com/reviews/sony/dsc_n1-review/ Hi there, just fixed mine. Had the same problem. Click on link above. Leisa1
Jan 20, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Sony Cyber-shot  DSC-N2 Digital Camera Logo
171 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
