ASUS Eee Lamborghini VX6-PU17-BK PC Netbook Logo
emon barua Posted on Sep 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keyboard repair i have some keyboard problem . but i don,t know how to open
Ben Worters
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 58 Answers
  • Posted on Sep 07, 2013
Ben Worters
Expert
Level 2:
New Friend:
Greenhorn:
Answers
58
Questions
0
Helped
7372
Points
163
MacBook Keys type incorrectly. I can't unlock my computer because the keys are all screwed up. This all of the sudden just happened and I don't know what's wrong.
You could try an external keyboard to get the password in, but it's also very possible that the cable for your keyboard is loose. It's worth it to open the case and make sure the keyboard cable is seated. I had a Toshiba go crazy like that and I found the cable partway out when I opened the case
My lenovo u530 laptop keyboard u,i,o,j,k,l buttons is not working properly if i am pressing those buttons 1,2,3,4,5,6 numbers is coming how to solve
Hello the keyboard is malfunctioning and needs to be replaced.
A computer repair shop or a lenovo dealer can change the keyboard for you.
I don`t know the exact price but we are talking about small money for the repair.
Good luck
My model 1025 - open the case?
These keyboard are all electronic and are not made to be repaired, unless one key is stuck but you don't need to get inside to unstuck the key. You must have broken the contact. You may have to look for a replacement.
1helpful
How do you open the keyboard on a gateway dx4200-09
Thats because it has a sealed keyboard, that kind of keyboard you cannot open it without destroying it, so don't complicate, just buy a new keyboard they're not expensive.
2answers
The letter Z key is not responding. I don't know how to fix it
Although having a laptop is certainly convenient, the all-in-one peripheral scheme (mouse, keyboard and speakers) can make individual repairs difficult, and a non-working keyboard can ruin the value of the entire package. However, there are some practical steps you can take to fix a laptop keyboard.
1.Diagnose the problem. When you press a key on your laptop keyboard, does it get stuck? Does the computer respond to your inputs? In almost all of these cases, the solution will lie in opening up your notebook's keyboard. However, to prevent extra work, press every key (do this in a word-processing program) and see which keys are affected. If every single key on a keyboard does not respond, you might have a software issue, which may require specialized help.
2.Clean the area around the keys that are not working. A damp lint-free cloth should be used to clean the surface of the affected keys. If you have stuck keys, use a Q-tip to clean under them, but take care not to pry the keys up, as this could result in further damage to your keyboard.
3.Remove the keys that are not working. Do this by grabbing some fingernail clippers and pulling out the hook-like fingernail cleaner extension. Use the small hook to gently pull the key up , which will expose a collapsible plastic hinge (commonly known as a key retainer) as well as a small rubber circular piece. Gently lift both of these pieces out of the keyboard.
4.Wipe the keyboard sensors clean with a dry cloth. The sensors are the little silver foil-like strips you see after your key components have been removed. Be very careful wiping these down--if they are damaged, they are very expensive to replace. Just gently dab it with a dry lint-free cloth to remove any dust/crumbs/particles that are interfering with your keyboard's functionality. Do not moisten the cloth with water or cleaning solution, as this heightens the risk for damage.
5.Reassemble and replace the keys. Simply fit the key retainer as well the little rubber piece together in the way you found them and then firmly press the key cap back in place.
6.Test your keyboard. Open a word-processing program and then press the replaced keys. If they still don't work, try restarting your computer, or activating a system restore point (to ensure that the problem is not software-related). If the keyboard is still not working, then you may want to think about taking the computer to a repair shop or replacing it altogether. (Keyboard repairs are very expensive.)
Thanks.
2answers
Dell set me a new keyboard to replace the original one because the keys are sticking and one fell off. No instructions and I don't how to lift up the plastic around the keyboard to replace it
Hi ktaydus.
Welcome to FixYa! How are you doing?
You did not specify the model of your dell computer.
You can check the manual online so that you know the step by step instruction on how to replace the keyboard of your dell computer.
You can go to this link: http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&~ck=anavml
Just select the model of your dell computer or enter the service tag which you can find on the bottom of your laptop.
Hope that helps. Thank you for using FixYa.
Neef a manual on how to replace the keyboard for a Gateway M1631u
I couldn't find instruction on how to replace keyboard even on gateway website. Don't know why they don't offer one. However, I found this below link from youtube for you. It shows how to step to disassembly and repair gateway parts. It is very easy to replace keyboard. Just watch the video, and I am sure you can do it.
http://wn.com/Gateway_Laptop
Other link is general information about the gateway keyboard for your model
http://support.gateway.com/s/Mobile/2008/Avalon/1015078R/1015078Rivr2.shtml
Good luck. If you are satisfied with this answer, don't forget to give me a good rate.
Thanks
My line spacer 1 & 2 green lights are flashing. Will not let me type or do anything. I changed the batteries, don't know what else to do.
I don't think you have a WW3500 as they don't have lights, if it is a WW1000 the keyboard is bad you can try my repair under WW1000 or contact Geo. Beyers Co. @ 800-392-8085 for a keyboard rebuild.
Tell them O'Reilly sent you.
DickyO
1helpful
2answers
Some keys are dead, can they be repaired
Usually, if keyboard keys are dead it cannot be repaired. But occasionally, if you remove the screws on the keyboard and flip it open and clean the pad with an eraser, it can be repaired. Just give it a try.
Don`t F keys...
is it sticky or not clicking at all?
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
