Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
All of a sudden my PC says that FreeAgent drive is damaged and inaccesible!I have all of my stuff saved on it!I tried on other laptop and it says the same thing! Pls help!!
  • Anonymous Apr 14, 2009
    i really need the stuff on that hardrive
  • 696 Answers
H Folks
This is unfortunately a common problem, if the drive is actually damaged you will likely need a pro like myself to get your data back. If it's only a software problem you can usually find a cheaper software recovery program that will do the trick.
What you need to do is go to the SeaGate website www.seagate.com and download SeaTools
install and run the program, select your drive(if it doesn't show up you need a pro)
select the smart test, then short generic then long generic. If it fails on any of them it's likely time for a pro, if it passes them all let me know and I'll point you to the appropriate cheaper software solution.
Chris
Armor-IT
Posted on Apr 24, 2009
I have a seagate Freeagent Go 500gb and suddenly it is not recognized by my laptop.
Try with another PC, If still not recognising, then You have to open the Casing of your external drive. If you have any Warrenty remaining for this Drive, then let company people fix this. if no warrenty then Remove the HDD from the casing, Connect HDD to the PC with another External casing, and backup your Data. If no ditection with this method, then your HDD is Dead. Keep finger crossed best of luck
Feb 01, 2011 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Hello, hard drive is not visible in the physical drive list. I was using my External HDD for almost 2months (500GB Western Digital). Suddenly the Drive missing. So followed my friends guide to get...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Sep 16, 2010 | Western Digital 320GB MyBook External USB...
I'm on Indonesia, exactly on Central Java... My HDD is Seagate FreeAgent 250 GB... I've plugged the USB cable and i connected the HDD to my PC... then, the led is just blinking for once, then black out,...
Aug 28, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 500gb Agentfree Making a beep every 15 seconds
It sounds like your hard drive is damaged my friend. Hard drives are very, very dilicate pieces of machinary. The disk is paper thin and any sudden jarring, especiaiy dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I knocked over seagate 500 freeagent and it beeped and groaned and nowcannot be accessed, orange light works but does not register on mycompter. What to do?
is damaged my friend. Hard drives are very, very delicate pieces of equipment. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
Jul 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer Doesn't See Freeagent Go 250 external drive
Uninstall all usb controllers from device manager and then restart your computer. Scan ur system with mcafee 8.5i
Jan 29, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
153 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
