Question about Sis 6326, (4 MB) Graphic Card
Installing AGP video card
I have an Acer Aspire T135 desktop with onboard graphics. I'm trying to install a nVIDEA GeForce MX4000 AGP video card. When I boot, the system temporarily recognizes the new card ( I have the monitor plugged into it)but, when Windows begins to boot, the screen goes blank and the signal light goes yellow.
  • K0NG Sep 13, 2007
    Therein lies the problem.....when the AGP card is physically installed, the output from the main (onboard) graphics doesn't get a signal to the monitor either. I tried booting with the AGP installed and the monitor connected to the OB and never got a signal at all.
    When I boot with the monitor connected to the new card,I initially get a signal.....it shows the details of the new card in the upper left corner...goes through the Acer bootup process, then goes blank JUST as it's going into Windows bootup.
    I booted into setup, checked the BIOS and I only have a choice between 'Onboard/AGP' or 'PCI'....nothing that lets me choose between the onboard AND the AGP.
    So, with the AGP card physically installed, there's no way to SEE my way through installing the drivers for it.
    President:
  • 317 Answers
Don't boot with the monitor connected to the card. You need to let it boot into windows and install the drivers for it first. Once you do that,shutdown and restart with the monitor plugged into it and it should work.
Posted on Sep 13, 2007
SOURCE:
Video card upgrading issues
Once the Video card is inserted the motherboard, it automatically selects the video card and at the BIOS settings just select the one with an AGP selection, then boot up the computer. Install the driver that comes with the video card. It might also ask you to restart... just select Ok then its done.
Jun 06, 2012 | Acer Aspire™ T135 PC Desktop
When i install windows 7 it says that it does not support aero effects howerver its memory is 128mb
hello
the MX4000 video card is not built to run aero it can run window 7 but not the aero effect, even if you fo to the support site of Nvidai to download the latest driver even in vista it does not have anything under that.
you can try the FX 5000 series of Nvida they still have an agp version
cheers.
Feb 25, 2011 | MSI Graphics Card - nVIDIA Geforce MX4000...
Hi. I want to play games on my Acer Aspire SA80 Desktop, but every time I install the game, it says the video card is not supported. I don't know what to do. Please help!
As per Acer this computer model has a Integrated SiS Mirage Graphic onboard card or a seperate
AGP 8x Add-on Card (selected models). It looks like the game you are trying to install requires advanced graphics card.
Please specify the game you are trying to install and also specify if you have a AGP card installed (and what is the make and model of the same).
If you do not have a AGP card installed , we can check the game specification and try to install a AGP card and check with it.
Jan 04, 2011 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Hi, my display card on a acer aspire t310 died. Which card do i need to get? AGP PCI-e?
AGP video cards are the best and latest generation video cards. Depending upon your requirements, especially it you play games that have high graphics requirements, go for the G-Force graphics card with as much video RAM as possible. Check out the various G-Force graphics cards.
Sep 10, 2009 | Acer Aspire T310 PC Desktop
Upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
Apr 29, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
I have an acer aspire m1610, I'm desperately trying to disable the onboard video card in order to add a geforce 8500 but there's no way to disable the onboard video card via the bios and the computer wont...
Are You sure the graphics card is not defect?
When I installed a graphics card instead of the onboard
circuit, the SIS Mirage was disabeled automatically.
I have installation CD for the graphics, of course.
Also, I thought that disabeling devices could be done
through the control panel, "hardware devices".
Sep 13, 2008 | Acer Computers & Internet
Graphic issue
It sounds like the refrsh rate set in Windows is too high for your monitor, try going into safe mode and setting the refresh rate to 60Hz.
Jun 26, 2008 | GE Asus V9400 /TD GeForce MX4000 64MB DDR...
GeForce MX4000 just installed it on my Gateway, when monitor pluged into card jack it dosen't work when I plug it into the gatway monitor jack the Mx4000 works but graphics look as if its running in...
Your new video card might be bad. Or you just might need to reseat your new card, might have a bad connection. Not sure how new your BIOS is? You might need to change a setting in your BIOS to stop using the on-board video.
My BIOS auto detected my video card, but your BIOS might not be that up-to-date.
Nov 10, 2007 | Pine Technology XFX GeForce MX4000, (64...
Sis 6326, (4 MB) Graphic Card Logo
207 people viewed this question
Top Sis Computers & Internet Experts
Thomas F. Schneider
Bart Fonteyne
robert roberts
Are you a Sis Computer and Internet Expert? Answer questions, earn points and help others
