Question about Twinhead N76PI PC Notebook
Not able to format my laptop
And not continue....
Hi, My dad passed on his Old laptop for my 7yr old to use for homework. I would like to restore to factory settings and can not. I have tried the thinkpad button as well as f11 to no avail. System
the system is not design to return to its orig.form or program ,unless you you format it using the format they used.you can used a formatted hardisk to replaced the orig.disk .or try the latest operating system that fits the requirement of your laptop.
Apr 12, 2013 | IBM ThinkPad Computers & Internet
How to reformat my samsung laptop?
Boot up with the Windows installation CD start and follow the instructions to install Windows.
Next Delete the existing Windows partition.
Next Create a new partition.
Next format this new partition - Format the partition in NTFS not a quick format. This will prepare the Windows for a clean install.
You can quit after formatting if you do not want to continue installing Windows.
Mar 21, 2013 | Computers & Internet
My laptop is countinuously on off
The reason behind the continuous ON or OFF might be the Operating system (OS) problem or it might be affected with any virus. Please check both and format the system and try again.
Thanks
Apr 01, 2012 | HP Compaq nc6220 Notebook
How to format r51
You can use your Windows installation CD to format the hard drive and install Windows again.
Boot up the ThinkPad with the Windows installation, follow the instructions to delete the existing partition, then create a new partition, then format the hard drive - do a full format, NOT a quick format.
You can then continue to complete the Windows installation.
Aug 06, 2011 | IBM ThinkPad R51 Notebook
I am installing os windows xp sp2 19 minutes left power shut off 3 times , when power on windows start up to mouse arrow pop up, what shall I to continue installation acer laptop?
The computer will continue to reinstall windows. It will say restarting installation, simply continue. If it stops again make sure you are using a good copy of OS CD and not a pirated one. Do a full format before attempting to install one.
Nov 28, 2010 | Computers & Internet
My Keyboard did'nt working , when i enter the boot menu to format my laptop , i cannot hit the button " ENTER "... so i cannot continue to format my laptop.... but the other button i can use like F3... i'm...
There should be two enter keys in ur keyborad try the alternative.
Else ur keyboard membrane might lost contact with the key. try replaceing the keyborad
Oct 26, 2010 | Acer Computers & Internet
Hang when format..
reformat and reinstalll the OS... make sure you have all the drivers setup files ready
Apr 19, 2009 | Computers & Internet
Format
Hi
two options
  1. The original restore dvd / cd can be used to format and restore the computer to the original state it came on.
  2. Use the windows installation cd, format the hard drive during the setup and then continue with installing windows, at the end you will need the device drivers and those are available at http://support.acer-euro.com/drivers/downloads.html
Jan 29, 2009 | Acer Aspire 5315 Notebook
Format compaq
if you have a operating disk(eg xp)boot from disk
in choices install or repair select repair.
at the promt type in d:
when d:/prompt appears type in format.
message appears something like all data will erased be continue y/n
type y
process begins...when finnished press all together at once ctrl,alt,del
system will restart and d: drive will be formatted
Dec 22, 2008 | Compaq Presario Notebook
I am trying to format my laptop and its letting me do that but when it shuts down after formating to install windows it just boot the cd up again to formating. any idea why ?
After you're done installing the windows components from the setup CD your computer will restart , then while its restarting it will ask you again to Press any key to Boot from CD so in order for it to continue the installation of the operating system dont press any key, just let it load by itself then that should continue now with the operating system setup..
Hope that helps...............
Sep 13, 2008 | Computers & Internet
Twinhead N76PI PC Notebook Logo
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Carl Rick
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
