Question about Toshiba Satellite 2455-S3001 Notebook
I have problems with Toshiba Satellite 2455-S3001 PC Notebook. The LCD screen is failing to come on. I can see faint images but not bright to see in darkness. Help.... emma.
  • Toshiba Master
  • 32,281 Answers
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Apr 14, 2009
  • 24 Answers
It seems, that failing LCD matrix inverter. You need to change it.
My Toshiba Satellite 2455 S305 Boots but the screen stays black. I have tried an F8 startup with no results. Does the screen need to be replaced or is there another part that might have failed?
Hi ccavanaugh38...
It could be a faulty screen or inverter causing your problem.
To try and find out which one it is, hook your laptop up to an outside monitor and start the computer, if the picture comes on then the problem is the screen, if if does not come on then it is the inverter in need of replacement.
Please take time to rate me
Aug 15, 2011 | Toshiba Satellite 2455-S305 Notebook
Put in new battery and it still won't charge
The first thing you need to find out is if your AC adapter is actually working.
Measure the voltage output. It should be about 18 volts or so.
If it is not putting out the voltage, it won't charge the battery and you will need a new adapter.
If it's OK, then your motherboard is bad.
Jan 17, 2010 | Toshiba Satellite 2455-S3001 Notebook
Hardware can I put into a ToshibaSatellite 2455-S3001 ?
hi, unfortunately the design of the laptop's are very rigid and only allow the extension of the ram memory and hard disk capacity up to twice the disk that originally brought.
Jun 08, 2009 | Toshiba Satellite M40-S417TD Notebook
Lost of media player volume after formatted due to virus attack.
check if the sound card is properly installed.
to check:
- go to start, point to computer, click manage, then click device manager. if there's a yellow sign on your audio, you need to install your audio driver
May 28, 2009 | Toshiba Satellite 2455-S3001 Notebook
Toshiba L35-S2171 bios password
Go here and read all about your problem. Surely you can find a way to do what you need to do.
Good Luck!
Mar 06, 2009 | Toshiba Satellite 2455-S3001 Notebook
I can't read my screen because it it too llght
You should have a Fn button on your laptop, and pressing that, combined with the button that has a sun on it should raise your screen brightness, if your screen only has one brightness setting, and it got much darker all of a sudden, your LCD lamp probably went out, in which case it is probably better to buy a new laptop, because those are expensive to replace.
Feb 26, 2009 | Toshiba Satellite P25-S507 Notebook
My Toshiba Satellite 2455-S3001 is running at a crawl. The cursor freezes and I can't get it to do anything.
Go to start>programs>accessories>system tools Disk Defragment.
Analyze the disk to see if it needs defragged.
You may also have a memory issue. Low memory can also cause this.
Jan 15, 2009 | Toshiba Satellite 2455-S3001 Notebook
Toshiba Satellite 2455-S3001 PC Notebook Drivers
You need to go here, then select your model from the list then download the drivers you need.
Thanks and please take a moment to rate as fixya.
Nov 07, 2008 | Toshiba Satellite 2455-S3001 Notebook
Toshiba Satellite A135-S4527 display problem
First try an external screen to see if your operating system is loading , if it does get a flashlight point it on the screen and check if you see a faint image , if you do it must be a bad FL inverter and if not a bad LCD, try calling toshiba tech 18004577777 to check your warranty if you still have warranty send it for repair.
Jul 13, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite 2455-S3001 Notebook Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
